Outside of North America South America, Europe, Asia, and Anywhere else where people are enjoying their S2000s
HELP! loss of 6th gear
Old 04-27-2009, 11:03 AM
Hi guys,just wanted to pick your brains.
after taking my s2000 out last week i discovered that i lost the use of my sixth gear.im abit stumped really as all my other gears work fine and yet when i put the clutch down to go into sixth it wont even go in.just wondering if this is a commen problem,or whether its going to be expensive to fix
thanx
chubs
chubs is offline
Old 04-27-2009, 11:09 AM
Village Pyro
TheSoundMan21's Avatar
I heard something along these lines before. Heard that one mechanic just forced it in and it started to work again. Just an idea from what I heard.
TheSoundMan21 is offline
Old 04-27-2009, 11:21 AM
It could be the shifter and not the transmission. Has the car ever been wet inside? If it has, the mechanism will corrode and gears will disappear. In mine the gate for fifth was gone. It costs about $20.00 for the parts if you don't destroy the boots.
Otherwise it could be a syncro
desmo4 is offline
Old 04-27-2009, 11:22 AM
can you put the car in 6th when stopped?
turbosix is offline
Old 04-27-2009, 11:27 AM
Village Pyro
Go with the above sugestions excluding mine those guys know what their doing.
Old 04-27-2009, 11:32 AM
So does it make any noise? Grind? Just not find 6th gear? Can you put it into 6th with the engine off and the clutch depressed? Sounds like it may be the shift fork either out of alignment or damaged but a problem like this is extremely hard to diagnose by messages in a forum.
Old 04-27-2009, 11:38 AM
no noise or grind,even with the engine off and the clutch depressed.just seems like the gate for 6th wont open?
thanx for the help everyone by the way.
chubs is offline
Old 04-27-2009, 11:41 AM
ok... sounds like the shifter/gate mechanism. Likely an easy and inexpensive fix.
Let us know.
Swingle1 is offline
Old 04-27-2009, 11:44 AM
thankyou very much,you've been a great help!
chubs is offline
Old 04-27-2009, 01:31 PM
J'sS2K's Avatar
sometimes, i have to force it a little to get in forth, especially when i first run it in the morning. it's weird. but after that, it works fine.
J'sS2K is offline
Old 04-27-2009, 01:53 PM
s2000isu's Avatar
After I let my car sit for 3 months it would not go in 6th I just used some force and it went in and shifted frine from that point on.
s2000isu is offline
Old 04-27-2009, 02:01 PM
J'sS2K's Avatar
my theory is that maybe 6th gear is not fully submerged under the tranny fluid so when you let it sit for a while it stuck due to the lack of lubrication..you just need to force it a little to get it going again...kinda like the brake pad sticking to the rotor after a rain or car wash...not sure but that's my theory.
J'sS2K is offline
Old 04-27-2009, 03:30 PM
H20
H20's Avatar
Wow
H20 is offline
Old 07-30-2009, 04:07 PM
Vezna31's Avatar
I can disprove your theory since I was looking at my tranny opened up by my mechanic yesterday. Gears 3-6 are not fully submerged, but there's a thin hollow rod that runs along side the gears that sprays oil onto them.
I lost 6th gear last week after my track day. My mechanic told me what part he thinks is the problem, but I can't remember what it is. He didn't have it fully disassembled yet.
Vezna31 is offline
Old 07-30-2009, 04:18 PM
I am pretty sure both theories are incorrect. The shifter has sliding parts and a spring which returns it to the normal position. If there is any corrosion in the mechanism the spring won't be able to move it. There is a TSB for this problem. Like I said in my previous post. If you take it apart and don't destroy the inner boot you can fix it it for about $20.00 worth of parts, polishing paper and some urea based grease. By the way, obviously 5th and 6th gears share the same pathway as reverse and that is where the spring and the sliding comes in.
desmo4 is offline
Old 07-30-2009, 06:19 PM
Sounds to me like a problem with the reverse lock out mechanism. (that's what desmo is talkin' about OP)
Work the gearbox into reverse over and over again...bang it a bit...bump it a little......try for 6th every once in a while....Once you get it into 6th....go from 5th to 6th over and over again.....
Do this with the engine off and the clutch disengaged.
You may be able to free it up.
jagg is offline
Old 07-30-2009, 06:31 PM
Vezna31's Avatar
Just talked to my mechanic and he said my problem is the selector sleeve.
Vezna31 is offline
Old 07-30-2009, 07:12 PM
Exactly
jonathan
desmo4 is offline
Old 09-28-2009, 07:45 PM
drake1 is offline
Old 09-29-2009, 07:14 AM
phins2rt's Avatar
WTF?
phins2rt is offline
Old 09-29-2009, 12:18 PM
This is plagiarism, send copyright fee to [email protected]
desmo4 is offline
Old 10-17-2011, 08:26 PM
s2k 6th not engaging;when it does engage, it gets stuck!
hey guys..wanted some input on my recently discovered issue on my supercharged S2K...today 6th gear wouldnt even engage..almost as if something were blocking it..but when i did get it to engage later on(dropped the rpms before trying to slam it into gear)...it was difficult to get it to disengage..
any suggestions of things to look into before i get it into my buddies shop and pay some serious cash...?
previous owner installed the clutch.. and sometimes it felt like 3rd gear was a millimeter or a couple millimeters off from where it usually is when i shift from 2nd to 3rd.. i dont know much about shifters but it feels like the alignment might be off or something has wiggled loose over time because i know i need a new transmission mount just from the feel of it...
thanks for the input and suggestions fellas!!!
s2ksweet is offline
Old 01-07-2012, 03:17 AM
  #23
gearbox issue
Hi just wondering if you got this problem sorted? I have the same problem only with first and second gear? Any advise?
sporty is offline
Old 01-08-2012, 01:21 AM
  #24
gears
Hey Chubs did you find a solution? I cant get 1st or 2nd gear in my Holden Astra........was it a big expensive job......please say no it was simple and cheap!
sporty is offline
supervinn
02-06-2012 05:20 AM
stewy612
8
02-13-2011 12:11 PM
Vezna31
23
06-28-2008 07:41 PM
tomyboy7
12
10-11-2007 04:07 PM
blacktrojan
8
10-20-2006 04:24 PM
Quick Reply: HELP! loss of 6th gear
