Go Back  S2000 Forums > Honda S2000 Forums > Off-Topic
TIPS ON PUMPING GAS, AND GETTING MORE FOR UR MONEY!! >
Old 04-04-2008, 11:57 AM
f20milo's Avatar
I don't know what you guys are paying for gasoline.... but here in
California we are also paying higher, up to $3.50 per gallon. But my
line of work is in petroleum for about 31 years now, so here are some
tricks to get more of your money's worth for every gallon..
Here at the Kinder Morgan Pipeline where I work in San Jose , CA we
deliver about 4 million gallons in a 24-hour period thru the pipeline.
One day is diesel the next day is jet fuel, and gasoline, regular and
premium grades. We have 34-storage tanks here with a total capacity of
16,800,000 gallons.
Only buy or fill up your car or truck in the early morning when the
ground temperature is still cold. Remember that all service stations
have their storage tanks buried below ground. The colder the ground
the more dense the gasoline, when it gets warmer gasoline expands, so
buying in the afternoon or in the evening....your gallon is not
exactly a gallon. In the petroleum business, the specific gravity and
the temperature of the gasoline, diesel and jet fuel, ethanol and
other petroleum products plays an important role.
A 1-degree rise in temperature is a big deal for this business. But
the service stations do not have temperature compensation at the
pumps.
When you're filling up do not squeeze the trigger of the nozzle to a
fast mode. If you look you will see that the trigger has three
(3)stages: low, middle, and high. In slow mode you should be pumping
on low speed, thereby minimizing the vapors that are created while you
are pumping. All hoses at the pump have a vapor return. If you are
pumping on the fast rate, some other liquid that goes to your tank
becomes vapor. Those vapors are being sucked up and back into the
underground storage tank so you're getting less worth for your money.
One of the most important tips is to fill up when your gas tank is
HALF FULL or HALF EMPTY. The reason for this is, the more gas you have
in your tank the less air occupying its empty space. Gasoline
evaporates faster than you can imagine. Gasoline storage tanks have an
internal floating roof. This roof serves as zero clearance between the
gas and the atmosphere, so it minimizes the evaporation. Unlike
service stations, here where I work, every truck that we load is
temperature compensated so that every gallon is actually the exact
amount.
Another reminder, if there is a gasoline truck pumping into the
storage tanks when you stop to buy gas, DO NOT fill up--most likely
the gasoline is being stirred up as the gas is being delivered, and
you might pick up some f the dirt that normally settles on the bottom.
Hope this will help you get the most value for your money.
DO SHARE THESE TIPS WITH OTHERS!
WHERE TO BUY USA GAS, THIS IS VERY IMPORTANT TO KNOW. READ ON
Gas rationing in the 80's worked even though we grumbled about it. It
might even be good for us! The Saudis are boycotting American goods.
We should return the favor.
An interesting thought is to boycott their GAS.
Every time you fill up the car, you can avoid putting more money into
the coffers of Saudi Arabia. Just buy from gas companies that don't
import their oil from the Saudis.
Nothing is more frustrating than the feeling that every time I fill-up
the tank, I am sending my money to people who are trying to kill me,
my family, and my friends.
I thought it might be interesting for you to know which oil companies
are the best to buy gas from and which major companies import Middle
Eastern oil.
These companies import Middle Eastern oil:
Shell........................... 205,742,000 barrels
Chevron/Texaco......... 144,332,000 barrels
Exxon /Mobil............... 130,082,000 barrels
Marathon/Speedway... 117,740,000 barrels
Amoco............................62,231,000 barrels
Citgo gas is from South America, from a Dictator who hates Americans.
If you do the math at $30/barrel, these imports amount to over $18
BILLION! (oil is now $90 - $100 a barrel
Here are some large companies that do not import Middle Eastern oil:
Sunoco..................0 barrels
Conoco..................0 barrels
Sinclair.................0 barrels
B P/Phillips............0 barrels
Hess.......................0 barrels
ARC0....................0 barrels
If you go to Sunoco. com, you will get a list of the station locations near
you.
All of this information is available from the Department of Energy and
each is required to state where they get their oil and how much they
are importing.
But to have an impact, we need to reach literally millions of gas
buyers. It's really simple to do.
Now, don't wimp out at this point.... keep reading and I'll explain
how simple it is to reach millions of people!!
I'm sending this note to about thirty people. If each of you send it
to at least ten more (30 x 10 = 300)...and those 300 send it to at
least ten more (300 x 10 = 3,000) .. and so on, by the time the
message reaches the sixth generation of people, we will have reached
over THREE MILLION consumers !!!!!!! If those three million get
excited and pass this on to ten friends each, then 30 million people
will have been contacted!
If it goes one level further, you guessed it ..... THREE HUNDRED
MILLION PEOPLE!!!
f20milo is offline
Old 04-04-2008, 12:10 PM
Village Pyro
TheSoundMan21's Avatar
Thanks for the info. Do you know where Quick Trip gets their gas from? Here in Oklahoma thats the main people to get gas from.
TheSoundMan21 is offline
Old 04-04-2008, 12:21 PM
running amuck
thats very good info man, thanks, and i hate kuwait and there f ing gas lol
army_boy is offline
Old 04-04-2008, 12:30 PM
DJJSR's Avatar
f20milo - Do you know where the oil from the Alaskan pipeline goes? Someone told me we export some of it.
DJJSR is offline
Old 04-04-2008, 12:40 PM
Trqless
SXY_S2K's Avatar
Ha, I got forwarded this email this morning, you beat me to posting it!
SXY_S2K is offline
Old 04-04-2008, 12:48 PM
windypoint's Avatar
I have a close friend that was a Captain for the BP ships that carry crude from Valdez. He either delivered it to Anacortes, Washington or Long Beach, California. I believe that is also the case or Arco. They are the two big players in Alaska crude.
windypoint is offline
Old 04-04-2008, 02:36 PM
f20milo's Avatar
lmao...
f20milo is offline
Old 04-04-2008, 02:37 PM
f20milo's Avatar
Dude, I have no idea, i just fowared it...
f20milo is offline
Old 04-04-2008, 02:54 PM
Where does Costco get their gas?
desmo4 is offline
Old 04-04-2008, 04:10 PM
running amuck
costco gets there gas from Jupiter, duh
army_boy is offline
Old 04-04-2008, 04:22 PM
Top Always Down
Dr. Jimbo's Avatar
I guess I'll start putting Arco in my stewie.
Dr. Jimbo is offline
Old 04-04-2008, 05:21 PM
St00pid Ricer
hammerhead300's Avatar
I hate to be a buzzkill here, but like a lot of emails that get passed around, this one's pretty dubious.
I did some research on the tips for saving on gas, and came up with this page, somebody in there gets pretty scientific about it. Also, with regard to foreign oil, snopes.com had this to say.
I'm not trying to one-up you here f20milo, as I know that you were just trying to help us save a little $$$. It's just that whenever I see stuff that's been forwarded thru email, I always like to do my research and find out what the scoop on it is. It turns out that in this case most of the info isn't entirely accurate.
hammerhead300 is offline
Old 04-04-2008, 06:54 PM
Neil's Avatar
You put the hammer on that there hammerhead..............
Neil is offline
Old 04-04-2008, 11:45 PM
Good call Hamerhead. This is just one more
piece of claptrap that has been circulating for
some time.
philiam is offline
Old 04-05-2008, 12:03 AM
B.A.M.F.
SilverS2K422's Avatar
cool, thanks for the info.
SilverS2K422 is offline
turbosix
10-01-2011 06:12 AM
Emmerick
Forced Induction / Nitrous
73
04-18-2011 05:38 AM
two faced rat bastard
Java's Just Drivin'
13
04-03-2011 08:49 PM
ChrisO83
11-14-2006 10:16 PM
Quick Reply: TIPS ON PUMPING GAS, AND GETTING MORE FOR UR MONEY!!
