Go Back  S2000 Forums > Honda S2000 Forums > Off-Topic
My dealer now charges $100.72 for an S2000 oil change. >
Old 04-26-2012, 12:53 PM
General Nuisance
Doug3's Avatar
I like my dealer, but have to admit that it's a little steep.
Doug3 is offline
Old 04-26-2012, 01:03 PM
agski's Avatar
Is that dinosaur or synthetic? Synthetic DIY oil changes cost me $45 and I get the satisfaction of looking under stewie's skirt!!!
agski is offline
Old 04-26-2012, 01:13 PM
Hybrid Hater
0tyrael0's Avatar
Criminy! Thats a lot. Mine cost around 75. But I just got some low profile raps so I can do it my self now. I like changing my oil. The ramps were $58 so I should make that cost up pretty quickly lol.
0tyrael0 is offline
Old 04-26-2012, 01:14 PM
EYECELLEM
$100 is too steep. Having said that my place will charge a little more for a S2000 oil change (about $50) because 10w30 is not purchased in bulk and we pour from 1 quart bottles.
Are you sure they're not quoting an oil change plus inspections, topping off fluids, battery check?
Glenn1 is offline
Old 04-26-2012, 01:17 PM
adagio's Avatar
$100??? $30 for 10W30 around here.
adagio is offline
Old 04-26-2012, 01:18 PM
Bug Zapper
Marioshi's Avatar
+11
Marioshi is offline
Old 04-26-2012, 01:19 PM
Bug Zapper
Marioshi's Avatar
Whats with people and the ramps? I think jackstands are just as easy. People get so lazy when it comes to jacking their cars up...
Marioshi is offline
Old 04-26-2012, 01:23 PM
General Nuisance
Doug3's Avatar
Mobil 1
Doug3 is offline
Old 04-26-2012, 01:24 PM
Party Rock Crew
starrman's Avatar
Where did you get them and what brand?
I always feel a bit more secure under a car that is on ramps vs. jack stands...getting old I guess...used to crawl under huge cars on a bumper jack.
starrman is offline
Old 04-26-2012, 01:38 PM
Dayum that's alot! I do my own too (even though it's not that fun on a lowered S). My Subie's is super easy.
Old 04-26-2012, 01:43 PM
i do my own on the s. synthetic every 3-5 k and they usually cost about 35 bucks
jsenclosures is offline
Old 04-26-2012, 01:54 PM
Hybrid Hater
0tyrael0's Avatar
The jack I have doesnt fit under the car until I put ramps under it lol. There is the S2K jack but... like you said, lazy.
0w30 is about 40ish + the filter so I save around 20 doin it myself.
0tyrael0 is offline
Old 04-26-2012, 02:11 PM
Bug Zapper
Marioshi's Avatar
If you are good, you can do it without lifting the car at all...assuming you arent lowered to the point where a catch can wont fit under.
Are you lowered? I have an el-cheapo jack that fits...barely.
Marioshi is offline
Old 04-26-2012, 02:31 PM
Hybrid Hater
0tyrael0's Avatar
Evasive Motorsports. They were on sale for 58 shipped a few weeks ago so I jumped on it. They're perfect.
http://www.evasivemotorsports.com/mm...00-ACCESSORIES
Yeah but not much. The H Techs lower it about .6. Then I have knois and they sit a tiny bit lower. Im probably a little under an inch lower.
0tyrael0 is offline
Old 04-26-2012, 05:58 PM
you people are silly....I ADD oil, 'n sometimes a filter if the mood strikes.
sidenote: don't ever buy a car that I'm selling.
jagg is offline
Old 04-26-2012, 06:04 PM
side sidenote: don't ever buy *anything* jagg is selling.
Last edited by RMurphy; 04-26-2012 at 06:05 PM. Reason: (in fact that side sidenote is so side, it's practically a sidecar)
RMurphy is offline
Old 04-26-2012, 06:07 PM
Damn! I just got my first oil change for her 10w 30 full check up filter for 40 bucks..
Kaotikkaos is offline
Old 04-26-2012, 06:13 PM
Never Slow down
Wayne's Avatar
Are you guys using an original Honda filter? I'm at home now but the OEM filter and gasket is around $10.00 plus 5.5 liters of synthetic oil at $10.00 each and you're already at about $60.00 without labour, so I figure my dealership would be around $75.00. Not cheap but you've got the Honda warranty behind you.
Wayne is offline
Old 04-26-2012, 06:18 PM
gasket for what ?
jagg is offline
Old 04-26-2012, 06:39 PM
Never Slow down
Wayne's Avatar
Drain plug gasket
Wayne is offline
Old 04-26-2012, 06:44 PM
really ?
this is not an item prone to failure.....it's designed to be re-used many times. why change it if it doesn't leak ?
jagg is offline
Old 04-26-2012, 07:03 PM
Party Rock Crew
starrman's Avatar
OK I looked at the ramps...do you use them just to get a jack under them? I use the Honda jack to jack it up to get the floor jack under it now.
starrman is offline
  #23
EYECELLEM
^^Also known as a crush washer. Costs .15 cents, so toss and use a new one, make sure no leaks from the drain plug.
Glenn1 is offline
Old 04-27-2012, 03:38 PM
  #24
Vtec_S2K's Avatar
Just bought everything for a royal purple oil change. Oil filter:$16 oil:$51 drain plug washer $.76.
Vtec_S2K is offline
Old 04-27-2012, 04:25 PM
  #25
i can never get enough leverage on the ratchet to loosen the bolt from above. always slips off.
turbosix is offline
Old 04-27-2012, 04:26 PM
  #26
really ?
^x2
used the same drain plug washer every oil change. bought car with 32k and it now has 103k on it. wipe it down, make sure there's no dirt on it, and have at it.
turbosix is offline
Old 04-27-2012, 05:53 PM
  #27
TheCarGuy2021's Avatar
Dang, changing my own oil with Mobil 1 racing oil doesn't cost that much!
TheCarGuy2021 is offline
Old 04-27-2012, 06:13 PM
  #28
Never Slow down
Wayne's Avatar
Bring your own oil to your dealer to save some money, but I would recommend an OEM Honda filter everytime. I've seen all kinds of things happen with non-Honda filters and when the customer goes back to "iffy-lube" they might give you your money back, not replace your engine.
Wayne is offline
Old 04-28-2012, 06:51 AM
  #29
Got S2000?
Peeps...DO IT YOURSELF! And leave the jacks & ramps in the shed.
I too can't get enough leverage with a ratchet, so I use a piece of 1" PVC as a cheater bar.
Lowered?? Drive up on 2x4s. Your pool babe will thank you for saving money.
Jim21680 is offline
Old 04-28-2012, 02:47 PM
  #30
royal purple sucks. Don't feel bad, though: I use to believe the hype when I first got my s2000, too.
dfws2k is offline
Old 04-28-2012, 09:23 PM
  #31
Vtec_S2K's Avatar
I have always used royal purple in everything and never had issues. I like it.
Vtec_S2K is offline
Old 04-29-2012, 06:41 PM
  #32
Daddy Zach's Avatar
I supply my own oil and I paid $30.00 for labour and filter and to let someone who knows a whole bunch more about cars than me have a look around
Seeing what's at stake a real bargain!
Daddy Zach is offline
Old 05-04-2012, 04:53 PM
  #33
that sucks. Thats why every car ive ever owned i changed my own oil
Spoonertuner24 is offline
t2k
06-25-2011 11:53 AM
thevpower
20
03-17-2011 01:17 PM
Doug3
35
09-26-2009 04:39 PM
DJJSR
06-23-2008 08:18 PM
Quick Reply: My dealer now charges $100.72 for an S2000 oil change.
