new owner window problem please help!
Old 07-26-2016, 11:00 AM
i recently bought a 2001 S2000 and i knew the window wasn't working it is almost down on drivers side and all the way down on [passenger side . the seller told me that he thought it needed a new master switch and i bought one but still no windows ? checked the fuse its ok i know about the lock thing not that any help would be appreciated the top works fine btw
thanks again tom
FlashS2k is offline
Old 07-26-2016, 12:33 PM
EYECELLEM
Do you mean window regulator? Is it making a slight noise like it's struggling to open/close? Regulator, switch, master switch or electrical problem from corrosion.
Glenn1 is offline
Old 07-26-2016, 12:52 PM
Originally Posted by FlashS2k View Post
I recently bought a 2001 S2000 and i knew the window wasn't working. It is almost down on the drivers side and all the way down on the passenger side. The seller told me that he thought it needed a new master switch and I bought one, but still no windows. I checked the fuse, its okay. I know about the lock thing and it's not that. Any help would be appreciated. The top works fine, btw.
Thanks again, Tom
It's amazing how simple it is to figure out what the OP was trying to say when you add all of the necessary punctuation and capitalization. It actually becomes coherent.
Old 07-26-2016, 01:04 PM
window problem
Sorry about the punctuation etc. I have been out of school a long time lol.
update : I found out the master switch was making a whining noise and was able to get the drivers side to work although not every time .The passenger window will not roll up or down and again the top works fine . I did remove the passenger side switch and checked for bent pins and corrosion and found none . thanks again Tom,
FlashS2k is offline
Old 07-26-2016, 01:14 PM
Take your can of WD-40 and spray every electrical contact. Spray every mechanical joint and then try pulling the window up using the switch and muscle power (Make sure the ignition switch is in the "run" position or the car is running). Do the same thing for both windows, the mechanism may just be corroded.
Old 07-27-2016, 07:10 PM
EYECELLEM
Ken strikes again!
Glenn1 is offline
Old 07-28-2016, 12:45 AM
Originally Posted by Glenn1 View Post
Ken strikes again!
Nah, Tom and I had quite a chat in the background. He's just a youngster and didn't know the ways of the old pharts.
turbosix
11-15-2011 12:48 PM
dtkix
09-25-2011 11:36 AM
gomezs2k
20
09-15-2011 06:38 PM
danheat
07-12-2011 06:28 AM
deepsea2000
09-30-2010 05:59 PM
Quick Reply: new owner window problem please help!
