How difficult to fix this?
Old 05-24-2011, 05:45 PM
General Nuisance
Doug3's Avatar
The problem is getting to the backside of it.
It got progressively looser and then just popped out.
Name:	power outlet.jpg
Doug3 is offline
Old 05-24-2011, 05:52 PM
Master Debater
Gadgetmanconnor's Avatar
from what i have creeped on around this website... i believe that you have to take the center thing out.... but dont rely on my observation
Gadgetmanconnor is offline
Old 05-24-2011, 05:56 PM
General Nuisance
Doug3's Avatar
I think that you're correct. BTW, that's not the answer I was looking for.
Doug3 is offline
Old 05-24-2011, 06:14 PM
I've gutted my interior to get at the soft top frame/motors. I was not near as bad as I expected. That said, as you can see from the instructions below that I got off the web(s2kca) the center glove box is step 6 so it's not exactly a cake walk unless somebody else on here has a shortcut. Oh, and I found the hardest part of the whole job #5, I could not for the life of me get that dumb tray out and over the roll hoops. Top up, top down, I just had a heck of a time getting that large tray piece out of car! For me that really was the only hard part of the whole job. But maybe that was just me... But I do think you need that out to get at the rear lower glove box screws if I remember correctly.
1. Remove seats.
2. Remove plastic trim (door sills, rear corner plastic, rear plastic).
3. Remove center console to get to the screws holding down the glove box.
4. Remove the trunk liners and the spare wheel to get to some clips holding down the rear plastic roof well trays.
5. Now remove all the roof well plastic pieces by unclipping the plastic body clips (this has to be done with the soft top in the 'up' position.
6. Once roof well plastics are removed, put the soft top in the 'down' position. Remove the glove box organizer.
7. Now remove the roll hoops.
8. You should now have access to the soft top assembly and motors. Unplug all soft top electrical clips.
9. Raise the top by hand and remove the 8 or 10 bolts holding the rear of the top down to the rear of the car.
10. Lower the top. Now remove the 4 bolts on each side holding the soft top frame to the chassis of the car.
11. Before lifting the assembly out of the car, make sure the soft top sides have been separated from the folds of rubber seal around the rear of the roof well.
12. Have a helper lift the assembly straight out.
13. Now have fun reassembling the plastic liner pieces back into place.
Silverstone_Ryan is offline
Old 05-24-2011, 06:18 PM
JDMJIMF22's Avatar
you dont heve to do all that i just fixed mine take the panel off behind the seal u can reach your arm inside the panel and screw it on from there it pretty easy
JDMJIMF22 is offline
Old 05-29-2011, 03:19 PM
General Nuisance
Doug3's Avatar
Doug3 is offline
Old 05-30-2011, 04:30 AM
Hybrid Hater
0tyrael0's Avatar
That thread you posted is on the right track. Post if it doesnt work out. I just put the interior back in to mine a week ago so its all fresh in my mind if you need to take more out.
0tyrael0 is offline
Old 05-31-2011, 07:55 AM
doug, it's as simple as that. if you cant get your hand back there still, you can lift up the center console and remove a few extra screws at the bottom of the glovebox (i did this first, so i'm not sure how much it helped, but it did seem to give more clearance)
turbosix is offline
Old 06-01-2011, 06:16 AM
Resident Aussie
Dotti90's Avatar
Step 1. 406
Dotti90 is offline
Old 06-01-2011, 10:00 AM
Top Always Down
Dr. Jimbo's Avatar
Put a little Loctite on the threads so it doesn't happen again. It's easier to put the nut back on if you have little monkey hands. I don't.
Dr. Jimbo is offline
Old 06-01-2011, 12:43 PM
General Nuisance
Doug3's Avatar
Funny you mentioned that. I stopped by the hardware store on the way home from the Post Office and picked up some blue Loctite. (I only want to do this job once!)
Doug3 is offline
Old 06-03-2011, 06:41 PM
General Nuisance
Doug3's Avatar
Fixed!!!! (major PITA) I'll wait until the Loc-Tite fully cures before I unplug the Garmin cable.
Doug3 is offline
Old 06-08-2011, 07:03 PM
smohan123's Avatar
I couldn't find any "metal cylinder thing" when I tried to do the fix like this:
Any suggestions? How big is the cylinder? Could it have become loose and dropped somewhere?
smohan123 is offline
Old 06-08-2011, 10:08 PM
owning the homanuelD THEpart manual are a wonderful hing.
desmo4 is offline
Old 06-09-2011, 03:33 AM
L8Apex's Avatar
I had the same issue. It's a very tinny, ring-like fitting. But, it must be on the wire harness somewhere back there because the only way to remove it is to disconnect the power outlet. I just followed the wires back from the back of the outlet until my fingers felt the fitting and slid it back onto the outlet.
L8Apex is offline
Old 07-04-2011, 06:10 AM
Mik
Weird Guys, I was just thinking about digging into my S2000 this morning and tightening up the cigarette lighter socket and was reading the forum and found this. Now I know how to do it.
Thanks.
Mike
Mik is offline
Old 07-05-2011, 12:34 AM
Top Always Down
Dr. Jimbo's Avatar
Thanks.
Mike
1 beer job brah.
Old 07-05-2011, 08:19 PM
Mik
No, it was 2 beers. Had to have my wife hold the plastic piece out just a bit to keep it from cutting into my hand. Finished the beer on the chairs out front. Didn't take long at all.
Mike
Mik is offline
Old 07-06-2011, 12:07 PM
Top Always Down
Dr. Jimbo's Avatar
Yeah, I had some pretty good gouges in my wrist after that job.
Old 08-12-2011, 02:57 PM
thanks for the Cig lighter write up
phonedrn8 is offline
Charlie Croker
Wheels / Tires / Suspension
40
11-06-2010 06:56 PM
Kimi01
09-04-2006 11:35 AM
Tyraid2K
04-21-2005 05:24 PM
Just Cliff
10-12-2004 01:51 PM
S2GRAND
06-24-2004 05:08 PM
Quick Reply: How difficult to fix this?
