DRL off HID's?? DIY?? Help
Old 05-21-2010, 07:19 AM
E30 Girl's Avatar
Hey guys I'm trying to find a do it yourself to install the DRL on my 2005 that I bought in Florida. I would like to have them run off the HID's instad of the high beams. Any help would be appreciated.
E30 Girl is offline
Old 05-21-2010, 08:10 AM
phins2rt's Avatar
I believe this cannot be done. The HIDs need the constant 35W. I am assuming you want a lower output than the low beams, right? That is why OEM use halogen bulbs for their DRLs. I think that is right but get a second opinion.
phins2rt is offline
Old 05-21-2010, 08:29 AM
there is this switch on the left side of the steering column...
turbosix is offline
Old 05-21-2010, 01:13 PM
Suzuka FTW
JDMHonda's Avatar
^LOLLLLLLLLL
JDMHonda is offline
Old 05-21-2010, 04:44 PM
E30 Girl's Avatar
Ya thank I'm driving a us car need drl for conversion and I can't see my dash when the headlights are on!
E30 Girl is offline
Old 05-21-2010, 05:41 PM
EYECELLEM
There's an instrument panel brightness button located on the left side of your gauges. Has a + for brightness and - for dimmer. Hold down the + button when head lights are on for full illumination of your gauges.
Glenn1 is offline
Old 05-21-2010, 07:43 PM
Got S2000?
I'm positive this can be done. You can have the HIDs lit from key-on, and have the switch on the column control everything else. Get yourself the S2000 wiring schematic and you're all set.
Jim21680 is offline
Old 05-22-2010, 06:11 AM
I don't have **** to do today, ill go outside and f ck around n see if I can make this work for you e30
turbosix is offline
Old 05-22-2010, 08:42 AM
E30 Girl's Avatar
If you are being serious thank you!
E30 Girl is offline
Old 05-22-2010, 08:46 AM
EYECELLEM
You'll be using up the HID's twice as fast, they're more expensive to replace than halogen bulbs.
Glenn1 is offline
Old 05-22-2010, 09:10 AM
from wiki:
The average service life of an HID lamp is 2000 hours, compared to between 450 and 1000 hours for a halogen lamp.[32]
turbosix is offline
Old 05-22-2010, 09:16 AM
e30g, do you actually give a **** about DRL or are you just trying to get your car to pass inspection?
turbosix is offline
Old 05-23-2010, 10:48 AM
E30 Girl's Avatar
It's a little of both. If I didn't have to do this I wouldn't bother just figured if I have to might as well do it the way I want. Why?
E30 Girl is offline
Old 05-23-2010, 01:01 PM
well, i havent had time to poke around so i'm sorry about that. but i asked because of the hid life problem. there's probably a very easy way to trip the relay with a 12v signal thats triggered when the key is turned.
but you could also just put a small switch under the dash to disable it when you want to.
turbosix is offline
Old 05-23-2010, 02:38 PM
In the service manual there are 2 sections, one for USA and one for Canada w/ DLR.
desmo4 is offline
Maximus
17
09-30-2015 08:22 PM
HiImBrandon
Parts For Sale
04-12-2012 06:20 AM
Wayne
05-10-2011 12:32 PM
kdude
Canada and Alaska
19
10-14-2010 06:23 AM
Wayne
12-12-2009 01:44 PM
Quick Reply: DRL off HID's?? DIY?? Help
