Turbo Psi and going turbo
Old 08-19-2009, 05:03 PM
hey i was wondering if i turbo my s2000 and leave it at 5 psi will my engine blow, also how much of a gain of whp will i get i wanna get low low 13s and at least 300 whp , also what internals shouldi get to back up the turbo when i have it at 8 or 9 psi
Zacxzx is offline
Old 08-19-2009, 05:22 PM
RL1924's Avatar
Im a pretty big newb with turbo and SC but im pretty sure 8-9 is not that that high and pretty sure 5 is pretty low. You should be able to run 8-9 stock internals and be making over 300 without any problems.
RL1924 is offline
im just sscared of blowing my engine
Zacxzx is offline
Old 08-19-2009, 05:45 PM
RL1924's Avatar
Well did you already do turbo? Im planning on going supercharged seems little less problems and reliable.. I could be totally wrong though just from what I see.
RL1924 is offline
s2000isu's Avatar
if you have the right stuff and you get it tuned you wont have an issue with 9 psi
s2000isu is offline
Old 08-19-2009, 06:00 PM
anyone got a video with a s2000 and cams in it
Zacxzx is offline
Old 08-19-2009, 06:23 PM
RL1924's Avatar
cams as meaning upgrading our cams? Pretty sure none out there do anything.
RL1924 is offline
Old 08-19-2009, 06:48 PM
s2000isu's Avatar
Any video with a running s2000 has cams in it. Aftermarket cams dont add power to these cars so people dont use them.
s2000isu is offline
Old 08-20-2009, 02:13 AM
boostftw's Avatar
Tune tune tune! Don't skimp on tuning or else ka-boom! I'm running a Greddy kit @ 10psi on a stock block tuned on AEM EMS.
click here for more info.
boostftw is offline
Old 08-20-2009, 09:35 AM
a safe boost level for any stock internal car is around 9lbs so they say..making 300 on 9lbs also depends on what turbo ur using...say u use a t25 to make 300 ur gonna need to run more than 9lbs because the cfm is different than i bigger turbo like a t3/t4..9lbs on a t3/t4 would flow about the same as a t25 on like 15-16lbs..if u wanna make good power with quick spool up i would go with a gt2871r( "r" stands for ballbearing if u didnt kno) if u have the money, if u dont u can always get the ballbearing t28 from a s15 silvia...quick spool up and u should see ur 300hp(with a good tune of course)
quicsilvia is offline
cdk456
Java's Just Drivin'
03-05-2014 04:51 PM
DTarantilles
Forced Induction / Nitrous
22
09-06-2011 01:09 PM
mariusz13
07-24-2011 04:08 PM
s2kx2
San Diego Chapter
59
02-04-2011 04:32 PM
deepsea2000
48
07-06-2010 07:03 PM
Quick Reply: Turbo Psi and going turbo
