comptech supercharger
Old 09-28-2011, 09:31 PM
Hello i recently bought a comptech sc from an 04 for my 03. from what i understand everything is the same except the fuel pressure regulator.
Should i purchase one for an ap1? Also how do i adjust it when i get the right one?
One more thing....This came wit ha 4" and a 4.25" pulley what would each put me at psi wise on my ap1?
turboed is offline
Old 09-30-2011, 08:59 AM
SRR
just install everything and dont worry about it
SRR is offline
Old 09-30-2011, 09:02 PM
L8Apex's Avatar
The FPR for the AP2 kit has a steeper curve and a slightly higher pressure limit to overdrive the injectors. You will need a vacuum pump, fuel pressure gauge and verbal instructions from CT Engineering's tech support to learn how to do it and what settings you should achieve. They do not have a tech sheet on this procedure.
The 4" pulley is intended for an AP1 install and, I think, should yield about 6.5 psi. The larger pulley will lower that pressure.
L8Apex is offline
Old 10-03-2011, 04:53 PM
I purschased an fpr for an ap1. I am picking the sc up on Friday. Hopefully tue install goes well.
turboed is offline
Old 10-12-2011, 12:48 PM
I'm running 7psi. Do I need to get it tuned or will I be fine with the fpr and the esm?
turboed is offline
Old 10-12-2011, 02:32 PM
Always get it tuned. You should also go to someone who has worked on a few s2000's. A base map for the most part is to get you to the tuner only. If i am mistaken then disregard that.
crossracing70 is offline
Old 10-15-2011, 07:08 AM
What should the afr be at idle , cruiseing and wot?
turboed is offline
Cody Strife
Forced Induction / Nitrous
9
06-23-2011 05:38 PM
v01dy
05-06-2008 04:32 PM
cvan
06-10-2007 10:19 AM
lilken
02-25-2007 09:53 PM
sooner71085
04-01-2004 07:25 PM
Quick Reply: comptech supercharger
