Boosted again - Page 2 - S2000 Forums
Boosted again
Old 02-01-2012, 05:07 PM
  #41
Party Rock Crew
starrman's Avatar
Sorry to hear about the pump...hope the leg is ok!
starrman is offline
Old 02-02-2012, 09:14 PM
  #42
TheCarGuy2021's Avatar
Wired everything up and went for a little cruise on its first tank of E85 tweaking the base map and breaking in the clutch. Boost comes on a LOT faster (~8psi @4500 RPM)! Still no WOT though, need to rent a dyno so I can tune it.
http://www.youtube.com/watch?v=SsU1x...ature=youtu.be
TheCarGuy2021 is offline
Old 02-02-2012, 10:21 PM
  #43
Old 02-03-2012, 07:23 AM
  #44
Awesome!!
Old 02-03-2012, 09:31 AM
  #45
Bug Zapper
Marioshi's Avatar
Hey CarGuy,
Sounds good. I kind of want to modify my subaru to use E85. Some pretty crazy power numbers for how little modifications and I have been noticing a lot of stations around here have it.
Marioshi is offline
Old 02-04-2012, 07:57 AM
  #46
*That One German Chick*
Cupkake.Luver's Avatar
Awesome. Looking good.
Cupkake.Luver is offline
Old 02-05-2012, 12:05 PM
  #47
Couldn't get past 14psi last night, gapped the plugs down and was able to do this today:
18psi @ 8300 RPM and still a bit of tweaking left to do.
Old 02-05-2012, 01:17 PM
  #48
Party Rock Crew
starrman's Avatar
What size pulley are you running?
starrman is offline
Old 02-05-2012, 01:33 PM
  #49
3.55"
Old 02-06-2012, 02:28 PM
  #50
Party Rock Crew
starrman's Avatar
How the heck do you get that much boost with that pulley? Got to be the trim?
starrman is offline
Old 02-06-2012, 02:54 PM
  #51
It's an S trim V-2, I've put ceramic bearings in and replaced the stock impeller with the 928 Motorsports billet impeller. The impeller itself flows ~15% more air across all RPM.
Old 02-06-2012, 02:58 PM
  #52
Party Rock Crew
starrman's Avatar
ahhh yes I have read of those...nice. Keep up the good job and the updates.
starrman is offline
Old 02-08-2012, 05:45 PM
  #53
Quick clip from the rear while driving around getting some logs.
First is a 2nd-4th pull, second is 1st-3rd.
Don't mind the long shifts, clutch isn't fully broken in yet and I'm trying to take it easy on it.
http://www.youtube.com/watch?v=E8nYL9aYUy4
Old 02-08-2012, 08:57 PM
  #54
Party Rock Crew
starrman's Avatar
That is so cool...love the flame thrower!
starrman is offline
Old 02-08-2012, 10:32 PM
  #55
Currently do not own s2000want one really bad what should I be looking for?
BoonDockerFatty is offline
Old 02-08-2012, 11:44 PM
  #56
Nice work. You could eat off that engine. Course it might taste a tad slick.
philiam is offline
Old 02-09-2012, 06:28 AM
  #57
I got the marshmallows!!!
Old 02-10-2012, 06:02 PM
  #58
Did some under the hood detailing today and I should have access to a much better camera within the next week. I think it will look better once I get a black valve cover (flat wrinkle just like the OEM finish) and plumb up my crankcase ventilation system. I also might need some ID 2000 injectors after some further street tuning revealed I'm pretty close to the limit of the 1000s. I'll have to bump up the fuel pressure and go do some more logging.
Old 02-13-2012, 06:07 AM
  #59
Looks great Carguy!
Old 02-25-2012, 09:36 PM
  #60
Master Debater
Gadgetmanconnor's Avatar
your car sounds amazing! what kind of exhaust do you have on that?
Gadgetmanconnor is offline
Old 02-25-2012, 10:24 PM
  #61
It's a 70mm Greddy Ti-C single and TP.
Old 02-26-2012, 05:42 AM
  #62
"I think it will look better . . . "
Hm-m-m-m-m . . well'iss jus' provez'itt: CG can be found by lookin' unda "FANATIC".
'Nuthin' less'n awesome CG . . as usual.
Java Junky is offline
Old 04-01-2012, 04:48 PM
  #63
Managed to make it to the strip today. Car still un-tuned to its full potential (about 75-100hp lower than its potential) and has a 4.77 diff and therefore I am using all 6 gears. Belt was slipping and only making 14ish psi (as opposed to 18 ). I also wasn't launching, made it into the 12's and trapped 115 considering all of the above. Oh, and it was a 2.1 60' with RE-11s at full street pressure (32psi).
http://www.youtube.com/watch?v=J9FIb_RnNCM
Old 04-01-2012, 05:56 PM
  #64
Old 04-01-2012, 06:45 PM
  #65
Party Rock Crew
starrman's Avatar
Nice runs... not sure but it looks like an old Mercury Montego? He must have seen your run prior and was a little nervous.
starrman is offline
Old 04-01-2012, 08:13 PM
  #66
Nice, but the first run appeared to be all down hill.
philiam is offline
Old 04-02-2012, 07:19 AM
  #67
Nice!!
Old 04-02-2012, 09:50 AM
  #68
Bug Zapper
Marioshi's Avatar
HUMINAHUMINAHUMINA!
Marioshi is offline
Old 04-04-2012, 06:00 PM
  #69
Back under the knife for a larger heat exchanger, gates belt (made for semi trucks), larger water pump, Comptech reinforced 4.10 diff, AEM IAT sensor to be mounted in the aftercooler, new crankcase ventilation system, removed all of the EVAP stuff (~20 lbs, none of it works with the AEM EMS anyway) and likely some diff mounts.
Old 04-09-2012, 07:27 PM
  #70
Forgive the messy garage, two projects currently going on. Heat exchanger came.
ID2000 injectors
Old 04-09-2012, 09:07 PM
  #71
Party Rock Crew
starrman's Avatar
OK, somebody stop this guy before he creates 9 second S!
Interested to know how the belt works...looking at switching my pulley to a Reichard pulley, hoping to eliminate the slip.
What injectors?
starrman is offline
Old 04-10-2012, 06:54 AM
  #72
Damn CarGuy! Can't wait to see what kind of numbers you're going to lay down when you're finished. Other project is a Supra??
Old 04-16-2012, 08:59 AM
  #73
They are ID2000 injectors.
Back to 4.10 gearing with Comptech reinforced housing and a Kaaz 1.5 way LSD.
Old 04-27-2012, 06:44 PM
  #74
Have been busy lately but finally solid mounted the heat exchanger today/plumbed it/filled it up and put the diff in last week. Just need to tune it! Should have time to do it in a week or two.
Old 04-27-2012, 08:00 PM
  #75
Party Rock Crew
starrman's Avatar
Looks good! what brand is the FMIC?
starrman is offline
Old 04-27-2012, 10:53 PM
  #76
It's just a air to water heat exchanger, not a FMIC. It's from eBay, essentially the same thing (pretty darn close) as the SOS one but far cheaper.
Old 04-30-2012, 06:33 PM
  #77
Car will likely be for sale within the next week or two once I tune it.
Old 04-30-2012, 09:15 PM
  #78
Party Rock Crew
starrman's Avatar
What? Is that in prep for the move west?
starrman is offline
Old 04-30-2012, 09:41 PM
  #79
Yes, not worth the hassle or risk of keeping this "under the radar" out there.
On the bright side, would likely pick up a CR within a year of the move.
Old 05-01-2012, 08:01 AM
  #80
Hybrid Hater
0tyrael0's Avatar
Wow car looks awesome. Should drive great with that diff.
0tyrael0 is offline
Quick Reply: Boosted again
