Best priced turbo kit
Old 01-09-2011, 09:23 AM
turbocoupedreams's Avatar
I know u get what u pay for but, there has to be a median here... whats the best turbo setup out there. Bang for your buck .... low price high performances
turbocoupedreams is offline
Old 01-09-2011, 03:13 PM
Hybrid Hater
0tyrael0's Avatar
I know more about superchargers for this car but I think it would be the gready kit.
0tyrael0 is offline
Old 01-10-2011, 10:35 AM
lonestarbuzz's Avatar
i've heard great things about the electric turbo. virtually no lag.
lonestarbuzz is offline
Old 01-10-2011, 10:51 AM
Seņor Member
backusstudio's Avatar
Nah, they suck.
backusstudio is offline
Old 01-10-2011, 11:12 AM
Chief Hata in Charge
Originally Posted by backusstudio View Post
Nah, they suck.
Dude that is a badass old vacuum. LOL...
Looks kind of Art Deco.
Back to the subject at hand.
I would get a turn key SOS blower kit for you car. They are precisely engineered, very reliable and the car can be driven everyday with their base kit.
It is a very good deal overall and if I can ever sell my freaking house I plan to get second S and drive it to them for the install.
Good luck with your forced induction search.
Cheers...
yashooa is offline
Old 01-10-2011, 11:18 AM
Seņor Member
Being serious for one moment that's what I would do as well.
Note that SOS http://www.scienceofspeed.com/produc...erchargers.asp sells a belt driven supercharger for the S2000, not a turbo. Probably a better choice for this engine and car.
Old 01-10-2011, 12:58 PM
thanks... that supercharger looks pretty expensive...4500 maybe???..but it only gives 100 hp upgrade...i bet its a much easier install and tune though....:/
Old 01-10-2011, 01:16 PM
Seņor Member
You don't want to shop for a forced induction setup for an S2000 by price, trust me. Talk about the most expensive money you ever saved.....
Old 01-10-2011, 01:34 PM
Don't think it has enough stock??
Old 02-14-2011, 01:18 PM
TegoS2k's Avatar
or have you thought about making your own turbo kit custom?
TegoS2k is offline
Old 02-14-2011, 01:38 PM
Bug Zapper
Marioshi's Avatar
Only 100 hp? thats over 40% increase over stock. That would give you almost and 8:1 weight to power ratio compared to 12:1 stock.
Thats a lot sir.
Marioshi is offline
Old 02-14-2011, 10:50 PM
Hybrid Hater
0tyrael0's Avatar
If you swap the head gasket you can get 400hp.
0tyrael0 is offline
Old 03-06-2011, 06:39 AM
why would swapping the head gasket bump up the hp?
JsBrown923 is offline
Old 03-06-2011, 07:37 AM
s2000isu's Avatar
Because a thicker hg lowers the compression. I personally am not a fan of this method and feel like you can make more reliable hp with the factory hg. 400 is possible and reliable with a good tuner and pump gas on a stock hg and you get to keep the factory quench area.
s2000isu is offline
Old 03-07-2011, 03:26 AM
Hybrid Hater
0tyrael0's Avatar
400 on pump with stock head gasket is reliable? What would you need for that like 11psi? I wouldnt think so but I know you have done boost so Ill take your word for it.
0tyrael0 is offline
Old 03-07-2011, 09:28 AM
Computer Blue
S2KCRick's Avatar
So a thicker hg makes it less reliable? What other negative impact is there when using a thicker hg?
S2KCRick is offline
Old 03-07-2011, 10:23 AM
Hybrid Hater
0tyrael0's Avatar
I wouldnt think it would make it less reliable. Its thicker so I would think it would make it more durable. But hey what do I know lol.
0tyrael0 is offline
Old 03-07-2011, 10:50 AM
NickBeam13's Avatar
Using a thicker head gasket to lower the comp, so you can in turn run boost, It is less reliable because a the thicker head gasket will be more prone to failure. But if your HP goal is 400, you probably wouldn't be running enough boost for that to be an issue. But 400whp can be achieved on stock compression so there's no need for thicker head gasket, which in my opinion would be the best route to go.
NickBeam13 is offline
Old 04-08-2011, 02:28 PM
Benw.17's Avatar
how is a thicker head gasket more prone to failure? from everything i heard the thicker head gasket is safer for running boost becuase it lowers the compression
Benw.17 is offline
Old 04-08-2011, 03:10 PM
s2000isu's Avatar
It also changes the quench area.
s2000isu is offline
Old 04-08-2011, 03:38 PM
RL1924's Avatar
400 is totally possible and reliable on stock hg... Just up some boost! 12-13lbs probably, Dont forget your not seeing that amount of boost until redline, so your car is not always seeing that.
RL1924 is offline
Old 04-09-2011, 10:20 PM
why not a 2jz or Rb26 in a ap1 or ap2?? if your going to spend $3000 to $5000 on a tubo or superchager??
baLLer0ffS3tRogue is offline
Old 08-15-2011, 06:55 AM
  #23
I bought the s2000 turbo kit which is around $800, did job well, I remember the store is like speedyracer
pboyd is offline
Old 09-06-2011, 01:13 PM
  #24
sp00led's Avatar
I've got a custom inline pro turbo kit but if I could do it all over again I would go with a Full-Race kit/manifold.
sp00led is offline
Old 10-11-2011, 08:24 AM
  #25
the gredy turbo kit to my knowledge would be the best bang for the buck kit.
kuba s2k is offline
Old 11-02-2011, 06:52 PM
  #26
just purchased a full greddy kit, lovin it
TeAvRoMiAxC is offline
Old 07-10-2012, 03:15 PM
  #27
Pfab http://www.pfabrications.com/inc/sdetail/872
gets consistent really high recommendations for good build quality and a really nice "starter" turbo build.
But, I guess it really depends on what your "buck" consists of. Greddy is by far the cheapest (cheapest of kits worth considering) but is fairly limited on upgradability and if you are seeking 375whp+ numbers you'll need to replace the e-manage eventually anyways.
All has to be taken from the perspective of what the ultimate goal is.
w00tw00t111 is offline
Old 01-07-2013, 08:28 PM
  #28
GREDDY BRO!!!
Ruben Aceves is offline
Old 09-21-2013, 09:46 AM
  #29
vtec just kicked in...
SickoS2k is offline
Old 09-21-2013, 07:08 PM
  #30
TakeMyAdvice,ImNotUsingIt
CherryPopper's Avatar
Do not forget....the most important thing you need to take into consideration is tuning tuning tuning!!!! Find a local tuner in your area that is familiar with s2000's. That is key! Also if you get a greddy ditch the emanage....and start investing into an AEM EMS or another stand alone ECU. With that you should achieve satisfying numbers out of that kit. If your a HP freak. Greddy turbo kit Sir, is not for you.
CherryPopper is offline
philiam
11
06-04-2012 07:58 AM
project*stealth
Parts For Sale
01-23-2012 06:53 AM
dia_cero2002
19
12-17-2005 07:44 AM
Red
10-26-2003 08:33 AM
Red
10-01-2003 08:44 PM
Quick Reply: Best priced turbo kit
