Sponsored by:
Sponsored by:
water still leaking into trunk
Old 03-21-2013, 01:47 PM
suzuka blue ap2
s2k360's Avatar
Attachment 5292so after I thought I fixed the leaking water into my trunk, I found some more in there. I am pretty sure I found the source, it is right behind the gas neck somewhere, on each side... the water is slowly leaking down into my trunk compartment. does anybody have any ideas where this might be coming from? someone please help! Would a hardtop cure this problem?
s2k360 is offline
Old 03-21-2013, 04:03 PM
i'll take anolther shot. bet this is the fix.
http://www.s2ki.com/s2000/topic/7857...ain-hose-clog/
bbcricketta is offline
Old 03-21-2013, 04:54 PM
L8Apex's Avatar
What event caused this leak? Was it rain?
That picture has me confused. Have you got one from farther back?
L8Apex is offline
Old 03-21-2013, 05:04 PM
suzuka blue ap2
s2k360's Avatar
Thank you, much appreciated!
s2k360 is offline
Old 03-21-2013, 05:06 PM
suzuka blue ap2
s2k360's Avatar
Yes rain causes this problem. I live in washington and it has been pouring the last few days. That picture is behind the gas neck in my trunk, I stuck my hand back there and felt water.
s2k360 is offline
Old 03-21-2013, 05:10 PM
suzuka blue ap2
s2k360's Avatar
Sorry that was wrong picture, my phone won't let me upload it, I will post it a little later
s2k360 is offline
Old 03-21-2013, 05:16 PM
suzuka blue ap2
s2k360's Avatar
This is where the water is coming from.
s2k360 is offline
Old 03-21-2013, 05:36 PM
2007 berlina black
that girl on the right has a lazy eye. I like that.
jagg is offline
Old 03-21-2013, 06:08 PM
L8Apex's Avatar
Given that location, my first investigation would be to see if the rear drain is clogged. That area is adjacent to the area of the rear drain.
I haven't brought my car home yet. So, I can't verify that you can do this. The rear drain is a square-ish plastic bowl that catches all of the run off from the top at the corners just adjacent to the roll hoops. The bowl attaches to a tube that runs down into the rear wheelhouse (wheel well). There is a check valve that connects to the tube in the wheehouse.
I think that you can pull the rear wheel and remove the valve. If the tube behind it is full of leaf and other debris, then you likely have a clogged drain. If so, you'll need to figure a way to vacuum it with a small hose and pull the debris out.
L8Apex is offline
s2k360
10
12-10-2013 06:48 AM
jyeh74
10
08-18-2012 06:52 AM
Hang
11-25-2011 02:17 PM
no_words_gal
11
01-03-2006 06:31 AM
Quick Reply: water still leaking into trunk
