Sponsored by:
Sponsored by:
water in my trunk :( soft top possibly?
Old 03-17-2013, 01:30 PM
suzuka blue ap2
s2k360's Avatar
So I live in Washington, and it rains alot. I went out to grab something from my trunk and noticed a little bit of mold, and sure enough theres a puddle of water. Is it the softtop leaking you think? I cant seem to fine where water is coming from, maybe its time for a hardtop...?
s2k360 is offline
Old 03-17-2013, 04:51 PM
Never Slow down
Wayne's Avatar
Trunk seal? Tail light seals? Maybe drain tubes for the top?
Wayne is offline
Old 03-17-2013, 07:44 PM
L8Apex's Avatar
I had a trunk seal problem after it was removed by a body shop for some cosmetic repair. I found in the service manual that you can adjust the trunk lid front to rear and side to side by loosening/tightening the four bolts on the trunk lid hing arms. You can also adjust the height of the closure by adjusting the screws in the rubber cushions and lowering the the striker bar held by two 6 mm bolts.
I took it to one of those high power brush-less car washes. After running it through, I could see that the water had accumulated inside the seal on the right. I did not have to adjust the striker because adjusting the cushion alone fixed the problem.
Good luck.
L8Apex is offline
Old 03-17-2013, 09:31 PM
suzuka blue ap2
s2k360's Avatar
thanks guys, i will check all of those seals and see if thats the problem. is it bad that water is getting in my trunk? i just hope it doesnt harm anything else
s2k360 is offline
Old 03-18-2013, 04:32 AM
yes, it is a bad thing. any time a seal is compromised it is not good. get your leakage fixed and dry out your trunk and all will be well. keep an eyeball on it for a while.
bbcricketta is offline
Old 03-18-2013, 05:42 AM
Good luck!
Old 03-18-2013, 01:29 PM
suzuka blue ap2
s2k360's Avatar
Unhappy
Okay guys... so I gutted out my trunk and here are some pictures of what I am seeing. I am kind of overwhelmed, I mean I dont even know where to start. There is water EVERYWHERE... literally. Any ideas?
ID:	5279   Click image for larger version
s2k360 is offline
Old 03-18-2013, 03:40 PM
here are some similar photos and a fix:
http://www.s2ki.com/s2000/topic/4655...trunk-picsfix/
Old 03-18-2013, 08:30 PM
suzuka blue ap2
s2k360's Avatar
So as I started to take off the clips to remove my bumper I noticed some water leaking out of this little seal, I put some sealant on it and its good to go!
s2k360 is offline
Old 12-09-2013, 02:28 PM
SulphurDave's Avatar
that sucks
SulphurDave is offline
Old 12-10-2013, 06:48 AM
rockstar143's Avatar
No, that was a solution. Eureka!
rockstar143 is offline
s2k360
8
03-21-2013 06:08 PM
L8Apex
Parts For Sale
09-27-2012 05:55 AM
no_words_gal
11
01-03-2006 06:31 AM
Quick Reply: water in my trunk :( soft top possibly?
