Sponsored by:
Sponsored by:
Rear Spoiler Question
Old 07-21-2010, 07:55 AM
Hi Folks, the rear spoiler on my S is attached by some kind of adhesive (looks like thick black double-sided adhesive tape). It appears to be coming loose and I'm wndering what you guys recommend for reattaching the spoiler. Tx
Frontier1 is offline
Old 07-21-2010, 08:02 AM
mlc
mlc's Avatar
Is it the OEM spoiler or the the OEM wing or something else?
Kevin
mlc is offline
Old 07-21-2010, 08:08 AM
Im not the original owner so I don't know but it looks like this:
Old 07-21-2010, 08:51 AM
mlc
mlc's Avatar
Here is the way it is supossed to be installed http://www.handa-accessories.com/S2000/s2kspoiler.pdf.
I am not sure if you can buy only the hardware.
Kevin
mlc is offline
Old 07-21-2010, 10:11 AM
Look inside the trunk and see if there are any studs protruding from the spoiler with nuts on them. If so, you can remove the spoiler get some 3m high bond double sided tape and put it back together.
desmo4 is offline
Old 07-21-2010, 10:40 AM
That's not double-sided tape, that is probably the gaskets that go between the spoiler and the trunk lid to keep water from going through the holes that are drilled to mount the spoiler. There should be 4 threaded mounting studs that hold the spoiler in place. Loosen those up, gently push the gasket back into place, tighten the mounts and you should be good to go.
Old 11-22-2010, 07:31 AM
vtekmofo's Avatar
Its a Soft gasket. There two long gasket pieces on that wing. I just put That Wing on My S2000.
vtekmofo is offline
Old 07-10-2012, 07:07 PM
2001 S2000
mstoops's Avatar
I am having the same problem as Frontier1. Does anyone know where to get just the gasket? Shoot, I'd settle for just the gasket material, I cut it myself. Thanks!
mstoops is offline
Old 07-10-2012, 07:25 PM
wwaallyy's Avatar
I just bought that same type of spoiler on ebay. Inside the box was the spoiler,2bolts,adhesive primer and a roll of 2 sided tape. I really don't want to drill any holes in my S as I may not like the look later on. There have been others who have used 3m tape and claim it holds real well on track and off. Any advice would be helpful...TIA
wwaallyy is offline
Old 07-11-2012, 06:05 AM
I just got the same one (e-bay, OEM Thing). I just used the shop's (bodyshop I work at) heavy duty 2-way tape, adhesion promoter and a couple alcohol pads to clean the surfaces. Make sure you clean the surface well and cover the spoiler with the tape. Should hold. I figured if it doesn't then I'll drill holes. Did this yesterday and it looks great. I'll post pics of the finished product later. Good luck wwaallyy!
Old 07-17-2012, 08:18 PM
wwaallyy's Avatar
SPOILER
: Some before & after pics..All comments welcome
File Type: jpg
File Type: jpg
File Type: jpg
File Type: jpg
File Type: jpg
File Type: jpg
wwaallyy is offline
Old 07-18-2012, 05:21 AM
Looks good!
Old 07-21-2012, 09:31 PM
Got Tofu?
TofuProductions's Avatar
If you don't mind my asking, OP - what exhaust are you running back there?
TofuProductions is offline
Old 07-23-2012, 06:07 AM
Looks like an Invidia Q300.
songzunhuang
Want to Buy/Trade For
09-15-2010 10:32 AM
CA Blue
8
09-14-2009 08:57 AM
SDHonda
07-07-2008 11:40 AM
Dr. Jimbo
44
05-03-2008 05:59 AM
Honda007
04-20-2008 10:13 PM
Quick Reply: Rear Spoiler Question
