Homeade intake plate: Lexan>aluminum
Old 06-21-2009, 10:44 AM
Here are some pictures of the lexan plate I made yesterday. Thought I would post some pictures. Its not finished as I need to re-bend one of the wings on the ride side for better alignment. I will be making a fiber glass "snorkel" to pass through the factory air guide and extend to the lower section of the bumper. This will be there to "feed" cooler air to the new plate. I was going to make a full snorkel similar to the spoon/muz, but after looking at the bottom of the hood(the angled cross section acts as the top of a snorkel) I decided that adding the snorkel would only restrict airflow as it passes over the radiator cradle....Hence the pinched area in almost all snorkels. I dont want to cut the hood for a larger snorkel, so I made this plate similar to the aluminum one that has been produced. However, being lexan it does not absorb as much heat as one made of metal. I left the plate clear for now, but I may paint it semi-gloss black to match the air box. I kind of like it clear too, it does not stand out so much. Sorry for such crappy/somewhat repetitive pictures. Wanted to show fitment.
S2K1185 is offline
Old 06-21-2009, 12:41 PM
Interesting. Nice job.
gomarlins3 is offline
Old 06-21-2009, 12:55 PM
J'sS2K's Avatar
I like it. nice job!!! how did you cut the lexan? They always crack when I try to cut them. LOL
J'sS2K is offline
Old 06-21-2009, 01:40 PM
Thanks guys! Well I know that acrylic/plexiglass will crack/break/chip when trying to cut or be folded. Polycarbonate(lexan) will not.
S2K1185 is offline
Old 06-21-2009, 07:02 PM
s2000isu's Avatar
plexi can be bent and cut without chipping.
s2000isu is offline
Old 06-21-2009, 08:41 PM
PRB2000's Avatar
sorry man, plexi/acrylic will break if bent. i deal with plastics at work everyday. poly/lexan will bend, especially when heated. i made my own cold air intake from home depot/ lowes 4" tube. it scoops air from grill, and hauls *** on highway. take-off from stop is a lil sluggish now though
PRB2000 is offline
Old 06-21-2009, 08:44 PM
TheCarGuy2021's Avatar
Plexiglass has to be scored along a straight line and bent/snapped for a clean cut.
TheCarGuy2021 is offline
Old 06-21-2009, 08:48 PM
PRB2000's Avatar
s2k1185, great job but let it go, the stock airbox is part of the governor, it restricts the airflow on purpose. take the top off and floor it on the highway, you'll see the high flow diff.
PRB2000 is offline
Old 06-21-2009, 08:49 PM
PRB2000's Avatar
true. i operate a cnc router, i cut it with a special carbide bit
PRB2000 is offline
Old 06-21-2009, 08:57 PM
Super Dooper Senior Newbi
Dmaye's Avatar
take some pic i'd like to see it.
Dmaye is offline
Old 06-22-2009, 05:21 PM
PRB2000's Avatar
scroll right, engine is dirty...... i like to OFF-ROAD
Size:  84.2 KBName:  100_0238.jpg
Size:  153.2 KBName:  100_0239.jpg
Size:  148.6 KBName:  100_0240.jpg
Size:  140.0 KBName:  100_0236.jpg
PRB2000 is offline
Old 06-23-2009, 12:09 AM
The factory airbox is apparently good enough for Spoon Sports to use it on their endurance race cars. Along with a similar designed plate.
S2K1185 is offline
Old 06-23-2009, 05:22 AM
PRB2000's Avatar
they only use their own parts, if they dont make an intake they leave it stock, plus those cars have regulations, there's only certain parts they can use to keep the race fair. notice there is no turbo, its like import nascar
PRB2000 is offline
Old 06-23-2009, 09:08 AM
Varietas Delectat
fltsfshr's Avatar
Check out puddydad's airbox all clear and lit, when the designer of the S2000 saw that he got a big smile and spent some time discussing it with puddy. They got some great pics together at the st pete gp.
fltsfshr
fltsfshr is offline
Old 06-23-2009, 09:55 AM
s2000isu's Avatar
Ok ill let the plexi guys at work know what they are doing is not possible thanks for the heads up.
Plexi can be bent. If it is heated correctly it will bend. Maybe not in an extremely sharp angle but it will bend. As thin as that material is I would imagine that you could get a nice radius if you heated and bent the plexi. Also at work we make clear boxes all the time with plexi that is cut on a table saw the edges need to be finished but they look crystal clear and have no chips when theyre done.
s2000isu is offline
Old 06-23-2009, 10:03 AM
oh no you didnt
gonna **** off some folks mentioning NASCAR here!! hahaha
turbosix is offline
Old 06-23-2009, 10:06 AM
Everytime I've hadda bend plexi I've jus' used'a heat gun'n'z farr'z chippin' . . maybe if yer usin'a prunin'-saw'r'n axe.
Iff'yer doon'itt like yuh wanna have good resultz it'll work out fine.
'Lookz good 1185
Java Junky is offline
Old 06-23-2009, 10:10 AM
we used cheap plastic in wood shop all the time to make things, however we had a line bender or strip heater
whatever i dont remember what it was called but it looked like this
turbosix is offline
Old 06-23-2009, 01:19 PM
PRB2000's Avatar
maybe we aren't on the same page, i'm talking about acrylic. modified SG or not. they don't even attempt to bend it at my work. we use fairly thick material too. sorry....geeez
PRB2000 is offline
Old 06-23-2009, 02:55 PM
Forgive the ignorance, but plexi'z plexi'n acrylic'z like Lexan, right?
'Never bent Lexan, but . . they've godd'a whole buncha thingz'n stuff made oud'uv'itt . . right?
Somebody'z bendin'itt.
Old 06-23-2009, 07:02 PM
Dmaye's Avatar
oh just to throw my .02 in poly base FR resin bonds grat to plexi encase anyone wants to glass over it for tuffer part
Dmaye is offline
cosmomiller
08-01-2012 12:41 PM
supervinn
Parts For Sale
01-03-2012 09:42 PM
waxfondler
09-28-2010 09:53 PM
mraasch
10
06-25-2010 07:41 AM
justin
06-10-2005 06:34 AM
Quick Reply: Homeade intake plate: Lexan>aluminum
