engine noise at start up
Old 10-28-2008, 09:40 PM
sfkjeld's Avatar
I own a pretty low mileage car, a 2002 with 20k on the clock. I know there is contraversary about buying low mileage cars. I never bought it. Low miles good; high bad. But I am beginning to wonder now.
When I start the car in the morning, there is for the first few secs, more mechanical noise. It immediately quiets after that. Once the car is warm, it does not make the same noise when started.
Wondering if there might be damage from starting the car after sitting idle for months (this was common for the previous owner). Internals fired up without enough oil coating.
Just wondering.
sfkjeld is offline
Old 10-28-2008, 10:38 PM
Takes a few seconds for the oil to circulate and part to warm up. Unless it's very loud it's not a problem. Keep in mind this is a high performance, aluminum block and head engine. Aint gonna sound like a sedan.
philiam is offline
Old 10-28-2008, 10:53 PM
Site Owner
Does it sound like a grinding noise for about a second or two after its already started? If so, I have had the same problem since I've had it. It only does it when its cold outside and a cold startup. Someone suggested changing the MTF since theres moving parts and that didn't fix it. It sounds like the starter is still trying to start the engine and is grinding after its started. Im thinking about taking it in to get it checked out.
D1sclaimer is offline
Old 10-29-2008, 06:26 AM
DJJSR's Avatar
I agree with Phil. I don't think it anything to be too concerned about. It takes a little while for the oil to get where it's going.
This is one good reason to be sure you use the proper viscosity oil that Honda recommends. Some people think a higher viscosity is better wear protection but that ain't so. Higher viscosity means thicker. Thicker means it won't flow as quickly. 70% of the wear on an average engine is caused by cold starts, so the quicker the oil flows, the less wear will occur.
Just my opinion, but I think synthetic oils "cling" to internal parts a little better than conventional oils, so when the engine is shut off and the oil drains down there is still a little film of oil to give some protection during cold starts. I read a test on this somewhere and it made sense to me.
DJJSR is offline
Old 10-29-2008, 06:29 AM
Banned for Life
dezignpro04's Avatar
A little rattle could be the sign of the TCT going bad as well. If it completely stops, its a little weird, but check into it. I know you have low miles but that spring will lose tension after a while I would presume. Make sure you have enough oil in the car a make sure you dont need a valve adjustment. Age > Miles.
My 02
dezignpro04 is offline
Old 10-29-2008, 10:16 AM
Village Pyro
TheSoundMan21's Avatar
Ill jump into this one. My car also makes the above explained noise. (I dont think thats much of a problem).
What is kinda concerning me is that when I start my S up I hear tinking from under the hood. Now while driving it will go away. But if I shut off the car just to fill up and check oil it comes right back. I aint got a clue what it is.
I also dont want to think as to how much a valve adjustment on her would cost.....
2002 70k miles
TheSoundMan21 is offline
Old 10-29-2008, 07:02 PM
"start my S up I hear tinking from under the hood"
Tinking?
philiam is offline
Old 10-29-2008, 07:20 PM
02 s2k
weigle54's Avatar
Id be willing to bet its the Auto tensioner.......mine sounds like that sometimes and then goes away...i will be replacing it (150) soon enough......this seems to be a very common problem w/ these S's.
weigle54 is offline
Old 10-29-2008, 09:08 PM
Site Owner
Mines definately not the TCT. It just grinds. Heres a vid I made of it. You kinda have to listen closely.
http://www.youtube.com/watch?v=h80wHXlTFEU
Old 10-29-2008, 09:22 PM
RL1924's Avatar
Yea that deff didnt sound like the TCT i had to replace mine so nice when that dam ticking is gone
RL1924 is offline
Old 10-30-2008, 11:01 AM
Village Pyro
Tinking?
I feel like one of those characters trying to make the noice for the mechanic and lookin like an idiot while doin it. Ill have to drag out a camera and see what I get.
Old 10-30-2008, 11:17 AM
DJJSR's Avatar
Take a video of you trying to make the noise, then post it here. I promise not to put it on youtube.
DJJSR is offline
Old 10-30-2008, 03:15 PM
Village Pyro
lol hell if I did that I would put it on youtube I might be the next numa numa vid.
Old 01-22-2014, 11:49 PM
Could be a seized idler/tensioner and the belt is rubbing on it....you can actually pop the aux belt off dead easy (15mm spanner on the tensioner) on the twinks and then start the car and see if the noise goes - can also spin the tensioner and idler and check for roughness…
taneshaleo is offline
Old 01-23-2014, 04:52 AM
mlc
mlc's Avatar
Sorry but 5+ year old thread??????
mlc is offline
Old 01-23-2014, 01:57 PM
Old 02-12-2014, 11:33 AM
Noise at start up
Mine would also making a ticking sound at start up. The oil pressure was fine then one day I started it and I it now sounds as if a bearing is bad I'm going to have to pull the engine and have new bearing put in. I hope that is the only issue. Does anyone know of a show that is good about working on these types of engines in the Tacoma, WA area?
rally68S2000 is offline
Old 02-12-2014, 05:38 PM
House of CR.
Vanishing Point's Avatar
You may just need something simple like a valve adjustment. Can you post a video of the noise so we can evaluate the problem? There is an active S2000 group in the PNW on S2KI.com if your looking for a shop recommendation.
Vanishing Point is offline
Old 02-12-2014, 07:57 PM
2009 Rio Yellow/A7E/A330
cosmomiller's Avatar
I agree. Make a video with the best sound you can get from about 5 or 6 feet in front of the car. Post it on the other site and see what you get. Billman is pretty good about identifying sounds. Often a TCT makes a ticking sound that can decrease. Its a common issuer. BYW, Billman will sell you his custom TCT that is guaranteed for life I believe. Better than sandblasting the worm screw.
Even changing oil brand/viscosity (0W-30) may change things along with a valve adjust.
cosmomiller is offline
Old 06-07-2014, 11:09 AM
+1
s2000vtecvtec is offline
Nagoya
20
12-12-2012 02:50 PM
S2Krazy21
03-10-2012 01:52 PM
hondamanslim
Java's Just Drivin'
12-12-2011 09:08 AM
liemdao
12-13-2005 06:49 AM
s2kwoah02
09-10-2004 09:14 AM
Quick Reply: engine noise at start up
