Broken TCT Bolt - Help!
Old 04-26-2019, 03:46 PM
s2kywalker's Avatar
In need of some desperate help. Broken bolt that needs removing, screw extractor didnt help much.
Any suggestions??
s2kywalker is offline
Old 04-27-2019, 10:56 PM
AP1Dave's Avatar
Looks like it's been drilled off center or did it break that way ? Either way that makes it tough. Anyway you need a fine thread nut a with an ID a little smaller than the bolt. Hold the nut over the bolt ( needle nose vice grips ) and weld the nut to the bolt through the hole in the nut. A hard wire feed welder ( not flux core ) is required and fill the nut with weld not just tack. Get help to hold the nut. Cover all critical surfaces with tape to avoid spatter damage. Get a few nuts because it usually takes a few trys. This is hard so don't get discouraged. If your not comfortable with the welder a machine shop that specializes in machinary repair should be familiar with the technique. will it run without the bolt ? save you the tow.
Don't worry it can always be repaired. Do you know what inserts are ? Good luck
AP1Dave is offline
Old 04-27-2019, 11:14 PM
AP1Dave's Avatar
Oh yea. I forgot. Don't try to move the bolt until it's cool.
AP1Dave is offline
S2Krazy21
03-10-2012 01:52 PM
rrui6930
12-01-2010 05:21 AM
yashooa
25
09-09-2010 03:19 PM
the.aviator2
10
06-10-2010 03:46 PM
TheSoundMan21
15
11-30-2009 07:05 AM
Quick Reply: Broken TCT Bolt - Help!
