Code P0411 - New correct placement >
Old 10-02-2018, 05:20 PM
I was getting a P0411 code on my 2005 S2000 which according to the OBD I ran is Secondary Pulse Air Injection - Incorrect Flow . I cleared it but every 10 miles it would return . I could discern no problems with the drivability. I looked under the hood to see if any hoses were loose and lo and behold I found a small hose underneath the serpentine belt. It was chewed in half . I removed it with mild difficulty and it had enough length to reconnect to a small box with a second hose. It must have had a bracket that came off and fell into the belt . The code has not come back after more than 100 miles so that's good but I don't know where to reattach the small box . If you look at my picture you will see I kinda used some electrician's tape and pulled it up close to the airbox. But I don't want to leave it like this . The tape will eventually fail and it will look pretty bad if I go to an oil change place. There is a small threaded hole directly in the middle of the picture I attached. I kinda of think it might go there but am unsure how . If anyone can help me without remarking on my obvious jury rigging I would greatly appreciate it. Thanks , Tom
P.S I hope I uploaded this picture correctly
montytw is offline
Old 10-04-2018, 05:48 AM
Hey Tom, do you see where it looks like a bolt would go on the air box right next to the little "black box" you have rigged up? It gets attached there. Not sure if just a bolt missing or if it snapped off but it goes there.
Old 10-29-2018, 01:49 PM
I thought that but mine must be missing a bracket because there is noting on mine that i could put a bolt thru.
montytw is offline
Old 10-30-2018, 07:03 AM
Some more pics to help you.
marshall
Forced Induction / Nitrous
06-16-2013 02:12 PM
asimdada
South
04-30-2013 08:36 AM
fresh06ap2
11-08-2012 08:05 AM
MaCkStRaP85
10
07-28-2009 04:31 PM
Honda007
07-25-2008 10:54 PM
Quick Reply: Code P0411 - New correct placement
