p1300 codes but but runs fine?
Old 09-29-2018, 05:57 PM
My 2001 S2000 has 155,000. It continues to run very well, but it throws trouble codes P1399, P0300, P0303, and P0304. Iíve checked all of the coils and spark plugs, and replaced injector #3. Iíve adjusted the valves twice and plan to do it again when the ďclick typeĒ valve adjustor tool I ordered from Amazon arrives next week.Recently, I took it to a shop here in town that does Hondas. They ran compression tests, both dry and wet. Dry: #1-200, #2-200, #3-170, #4-170. Wet: all 4 were 200. They concluded that #3 and #4 need rings.Today, I did a leak-down test on all cylinders. First I warmed up the engine. The results: All had 5% to 8% leakage. I listened for leaks in intake, exhaust, and crankcase locations. I could hear air through the dipstick tube during the tests for #3 and #4. Later, I tested again after the engine had cooled down. Again, all were within 5 to 8%. I could hear the air through the tube with the same relatively low level of intensity as before, but this time during the tests for all 4 cylinders.I donít really think the car needs anything. But, my problem is I canít register the car with the State of California because of the trouble codes. My question is do I really need to tear down the engine to fix it or is there more I can try to solve the problem?Thanks for your thoughts,
Jim
jrb2 is offline
Old 09-30-2018, 09:37 AM
Got S2000?
Check for clogged EGR passageways?
Jim21680 is offline
2K4VBPEP3
18
02-16-2012 09:43 AM
Doug3
10
02-06-2012 05:54 AM
myxgt
8
09-27-2011 08:39 PM
smokinjoe
01-31-2011 08:17 PM
S2000Granada
Outside of North America
45
08-25-2008 09:08 PM
Quick Reply: p1300 codes but but runs fine?
