EPS Light and Soft Top Problems
Old 05-20-2017, 03:58 PM
So my EPS light is on and the turning is very stiff when i go to the left or right too much. It was never a problem until i hit a large pothole with a gas line sticking out of it. Not sure what the damage is but everything looks fine under the car can't figure out what i need to do.
The soft top with go down with the control but it wont go back up except for manually. Any advice would be appreciated.
Christopher Samer is offline
Old 05-22-2017, 08:00 PM
flyingarmadillo's Avatar
EPS is the Electric Power Steering, I'd look for a blown fuse first, then look see if there's wiring lose under the car. The EPS fuse is in the small auxiliary fuse box under the hood on the drivers side.
The fuses for the convertible top are in the primary under hood box near the battery on the passengers side. There's also a connector under the dash on the passengers side that may have come lose, particularly if you had a passenger with you at the time.
flyingarmadillo is offline
Old 10-04-2017, 04:09 PM
So I fixed the top by replacing the fuse switch. However the eps light still turns on from time to time and disables my vtec.
Old 11-25-2017, 02:07 AM
There is a fuse in the cockpit fuse box that will disable the power steering and the vtec. The car will still run and drive but it also knocks out most of the dash display. Sounds like an intermittent open in the power steering circket. Look for a damaged wire by the steering shaft and rack. I hate intermittent problems. Good luck.
AP1Dave is offline
L8Apex
Parts For Sale
09-27-2012 05:55 AM
Smoker
9
05-11-2010 06:44 PM
S2000_786
10
07-09-2009 12:50 AM
Dinanbm3
02-12-2008 02:04 AM
Quick Reply: EPS Light and Soft Top Problems
