HELP!!! 2002 s2000 ignition coil pack and Secondary Air Pump >
Old 01-01-2017, 03:23 PM
I just purchased this vehicle. When I was going to change the spark plugs every single ignition coil pack was soaked in oil. I end up cleaning the all the oil out and the ignition coil packs. After everything was cleaned up and install, I started the car and now Check Engine light with the codes P0301, P0303, P0411, and P0300. So I'm looking for Ignition Coil pack for my 2002. Does anyone know if I use the AP2 2004-2005 ignition coil packs one AP1?
Any advice for repairs on the secondary air pump?
Hangman85 is offline
Old 01-01-2017, 05:42 PM
Can't help you on the coil packs, but there are kits available which allow you to bypass (and remove) the secondary air pump.
Old 01-01-2017, 08:51 PM
Do you know what kit it is and is it bad to drive with the secondary air pump not fixed?
Old 01-02-2017, 04:57 AM
Try this: Google honda s2000 bypass secondary air pump
Too many responses to list but that will answer both of your questions.
Old 01-02-2017, 04:29 PM
[QUOTE=kgf3076;245123]Try this: Google honda s2000 bypass secondary air pump
Thanks
Old 01-17-2018, 09:59 AM
coil packs are same. I think the oil you had was from the seals leaking on the valve cover, when you remove it the seals go around the openning on the valve cover.
zxnazx(tt) is offline
Old 01-17-2018, 04:54 PM
The pump basically just helps heat the cat up quicker for emissions reason, it only runs during start up until the cat gets to whatever temp it wants to see then shuts off until the vehicle is cold again. Unless you're driving it in the winter I wouldn't worry much about it. I'd still want the engine light out personally, but you can either fix the system or get a bypass kit like the one already mentioned. Hope this helps!
Toyonda002 is offline
NISMA S2000
09-01-2015 09:59 AM
smiga
06-12-2015 09:32 AM
jsenclosures
Want to Buy/Trade For
03-19-2013 03:49 AM
JDMzimbo
9
01-26-2011 11:27 PM
cris2k
05-11-2010 12:10 PM
Quick Reply: HELP!!! 2002 s2000 ignition coil pack and Secondary Air Pump
