Bad Cat
Old 06-26-2015, 11:18 PM
Top Always Down
Dr. Jimbo's Avatar
Bad Cat
Long time, no see you guys and gals.
So I'm on my second cat. My first one (2001 S) went rattling and broke my secondary O2 sensor, another S friend gave me another used cat that's lasted 2+ years and now it's rattling and throwing a a code for the secondary O2 sensor again. I know that the innards of the cat have broken off the tip of the O2 sensor like it did before (my S sounds like a diesel). My question is: is it going to cause harm to my engine or just be a problem when i go to smog check in California? I'm going to replace it, I just want to know if it's doing harm. I tend to throw CEL's for cylinder 1 & 2 as there is a leak between cylinders 1 & 2. This is happened since 70K and I have 151k on the clock. Being my DD, i haven't had a chance to pull the head. No chocolate milkshake oil or coolant or cumulous clouds out my tail pipes, there must be a leak between cylinders 1 & 2 as confirmed by my compression and leak down tests.
Okay to drive with the cat honeycomb broke loose or am I looking at major problems?
Dr. Jimbo is offline
Old 06-27-2015, 05:56 AM
The cat is probably not an issue but the leak between 1 and 2 darn sure is. The only way a cross cylinder leak is possible is a bad head gasket. Left long enough the hot gasses will create a groove between the adjacent cylinders. If the leak is on the top side of the HG then you damage the head if it is on the lower side you damage the block. You easily ruin a block or a head.
cdk456 is offline
Old 06-27-2015, 02:06 PM
Top Always Down
Dr. Jimbo's Avatar
Well, I'm probably F'd. 80k since I started getting the CEL and finally dx'd at 100k.
But thanks for the info. I guess drive it til it dies.
Old 06-29-2015, 06:52 AM
I'll take it off your hands Jim. $100 shipped to my door!
BTW, good to see you are still around.
Old 06-29-2015, 03:00 PM
EYECELLEM
[QUOTE=Switchblade;242786]I'll take it off your hands Jim. $100 shipped to my door!
That's one expensive cat! What breed, Siamese?
Glenn1 is offline
Old 06-29-2015, 03:01 PM
EYECELLEM
[QUOTE=Dr. Jimbo;242770
But thanks for the info. I guess drive it til it dies.[/QUOTE]
Poor cat, hope you're feeding it at least.
Glenn1 is offline
Old 06-29-2015, 03:08 PM
EYECELLEM
Sorry, couldn't resist, slow day at work.
Glenn1 is offline
Old 06-29-2015, 09:43 PM
Top Always Down
Dr. Jimbo's Avatar
C'mon man, at least $150. I've got an aftermarket cup holder.
Old 06-30-2015, 06:36 AM
$125 final offer!
tuna79
South
11-20-2009 03:17 AM
Blackdragon
8
08-24-2008 03:23 PM
AeroS2000
25
06-15-2008 10:33 PM
Blackdragon
Forced Induction / Nitrous
27
04-05-2008 03:40 PM
Asil
07-25-2007 04:35 AM
Quick Reply: Bad Cat
