AC takes awhile to get cold
Old 08-01-2013, 03:33 PM
It has about 106k miles.
I notice when I turn on the car, it takes a good 5-10 mins before the AC gets cold. I took it in to my shop who charged me $100 to do a AC service. He filled the freon because he said it was low and checked for leaks. No leaks.
But afterwards, it still takes 5-10 mins before it gets cold. I called the shop and he says it has something to do with the center console and the door not opening. But I explained that that has nothing to do with the side vents (driver and passenger side) He seems to think that the middle section and the levers not opening all the way, affects the entire AC system, including the sides. I think I am getting the runaround. Just replaced the cabin air filter. Could it be the AC compressor? May be unlikely because AC does work, just takes 10 mins after car is started to get cold.
Does anyone else have this issue or know what it might be?
jyeh74 is offline
Old 08-01-2013, 05:18 PM
Never Slow down
Wayne's Avatar
First of all you need to see if the A/C gets down to the proper temperature. Depending on the outside temperature and the humidity the A/C will take longer to get cold and it will only go so cold if it is really hot out. There is a calculation that is done to see how cold it should in relationship to the current temperature. Now if the freon was low it had to go somewhere. You should get the shop it put some A/C dye in the system so you can pinpoint any small leaks.
Wayne is offline
Old 08-01-2013, 06:07 PM
TheCarGuy2021's Avatar
Any reputable shop should be able to look at the pressures (high side and low side) with the system running and be able to make a proper diagnosis.
TheCarGuy2021 is offline
Old 08-01-2013, 07:27 PM
yup....this ain't rocket science.....lest ye be extra-picky 'n all.
jagg is offline
Old 08-02-2013, 05:15 AM
Take it to another shop. And +1 with CarGuy.
Old 08-08-2013, 09:58 PM
2009 Rio Yellow/A7E/A330
cosmomiller's Avatar
Your shop guy is thinking that the doors that control heat/air are computer controlled. Lots of cars are like that and it is a common problem. A reset of the system solves that. Some doors become warped and/or the foam seals become sticky causing them to malfunction and presto, no cool air. Not sure if this car has a problem with sticky doors. Big problem with Ford.
cosmomiller is offline
Old 08-09-2013, 07:26 AM
Vtec_S2K's Avatar
Just put the top down....................Hello
Vtec_S2K is offline
Old 08-09-2013, 10:49 AM
EYECELLEM
Glenn1 is offline
Doug3
10-10-2012 12:03 PM
TTMartin
04-23-2011 09:01 AM
Marrk
03-18-2010 08:54 PM
RayYay
15
01-30-2010 02:31 PM
Vezna31
07-14-2007 01:49 PM
Quick Reply: AC takes awhile to get cold
