squeaky/ crackling clutch pedal
Old 11-04-2012, 05:42 PM
so this started recently where whenever i push in my clutch pedal a certain distance it squeaks.. but now after a couple weeks i feel like its getting worse. it squeaks sometimes, then other times sounds even worse like a crackling noise. any ideas? i just replaced the clutch master cylinder. Thanks.
s2kpat is offline
Old 11-04-2012, 06:38 PM
House of CR.
Vanishing Point's Avatar
This sounds like this issue exactly, try the DIY described in this link.
http://www.s2ki.com/s2000/topic/3707...-clutch-pedal/
Before attempting the above try lubing the pedal arms/hinge points. Also lube the slave cylinder/clutch fork, or also the clutch fork to throw out bearing arms. Use a quality grease for these operations.
Vanishing Point is offline
Old 11-04-2012, 09:58 PM
i looked under my dash where the clutch pedal is, there are springs it seems?? above the clutch pedal, it sounded like that is where it was coming from.
s2kpat is offline
Old 11-05-2012, 05:54 AM
Is your clutch master cylinder leaking by chance?
Old 11-05-2012, 01:13 PM
nope, just replaced it. it was before.
s2kpat is offline
Old 11-05-2012, 01:29 PM
Ah, I see. Sometimes they start squeaking when they have a leak. And I just saw that you replaced it in your original post.
Old 11-05-2012, 02:25 PM
yea there are springs above the clutch pedal, i think thats the problem, ever heard of this before? maybe it isnt greased right?
s2kpat is offline
Old 11-05-2012, 05:37 PM
I had a similar noise from the gas pedal on one of my cars and I removed the return spring, coated it with lithium grease, reinstalled it and the creaking noise was gone. I would try the same for the spring your are seeing on the clutch pedal.
NFRAP2 is offline
Old 11-05-2012, 07:23 PM
alright, thanks for the input guys
s2kpat is offline
turboed
04-04-2011 06:21 AM
ramon4
07-30-2009 10:11 AM
moos500
12
05-05-2009 08:57 AM
chazdawg35
06-26-2008 08:08 PM
s2lovely
11-03-2004 02:55 AM
Quick Reply: squeaky/ crackling clutch pedal
