Did the timing jump?
Old 10-03-2012, 11:16 AM
Lately, car won't start - plenty of spark - excellent compression - has injector pulse - 60 psi fuel at start. The car would like to start but no go.
I ran out of idea and opened my valve cover to check the timing.
Did the timing jump a tooth? How is it possible the timing chain can jump a tooth?
Is there a procedure how to re-time it?
http://imageshack.us/a/img193/4505/timingmarkcopy.jpg
Busanostra is offline
Old 10-03-2012, 11:32 AM
House of CR.
Vanishing Point's Avatar
I assume it turns over? If not, have you checked your main fuse(s)? What year is your S, pre-04 S's had circuit board issues associated with their immobilizer. Can you push start the car? You might have to take it to a dealer to have them work on the key/immobilizer issue if that is the issue.
Vanishing Point is offline
Old 10-03-2012, 01:12 PM
Thank you....
Correction.....the timing did not jump, I mistakenly mis-aligned the harmonic balancer.
The first mark at the balancer is the right one and the cam sprockets aligned exactly.
Then...I don't know what else to do.
I have an AEM EMS, I thought its my standalone ECU, I went back and plugged my stock honda ecu but still will not start.
Old 10-03-2012, 02:10 PM
House of CR.
Check your 40A main fuse and the 100A battery fuse first, it they are intact I suspect its the immobilizer key function or the circuit board.
Old 10-03-2012, 02:26 PM
Thank you....my car is a Lotus 7 with Honda s2000 supercharged.
The stock ecu has no immobilizer. I deleted them a while back and using it for a while until i replaced it with aem because of the supercharger. They are both working before with no issue.
As I said...plenty of sparks-fuel pressure - noid light blinking during the injector test - lots of compression too. Don't know what else to look. It's not the crank and cam sensor cause there is a spark. The TPS measured .030 at rest and 4.5 at wot.
Will a bad wire at the map sensor will cause not to start?
I swap my stock ecu, still no go. I put a bunch of grounds in the engine, still no go. Very frustrating. The sparkplug is always wet during cranking.
Old 10-03-2012, 04:54 PM
Party Rock Crew
starrman's Avatar
I see you did a compression test, did you do a leak down?
This is weird, spark, fuel, cranking, both aem ems and stock ecu have been tried....not sure
starrman is offline
Old 10-04-2012, 05:09 AM
Starrman......yep! this is weird, but HOLD ON! after 3 days that I left the cylinders open (no sparkplugs), I cleaned the plug and put it back -----broooooooom! the car started!!! What da..........
I think what happened was, the cylinders are flooded, the gas dissipated after 3 days.
It idles bad because the injectors are 750cc. The reason for this lumpy idle, I put the stock ECU back instead of the AEM EMS (which is mapped for the 750cc)
Here is the engine: http://imageshack.us/a/img29/1213/7engine001.jpg
Thank you folks...
Old 10-04-2012, 07:49 AM
Party Rock Crew
starrman's Avatar
I would get some id 1000's and put the aem back in and get a good tune.
starrman is offline
Old 10-04-2012, 08:00 AM
i'M AFRAID if I put 1000cc and put more power, I will not be able to control a car with a weight a bit over 900 lbs.
Old 10-04-2012, 09:23 AM
Party Rock Crew
starrman's Avatar
Yes that could be an issue...I drove a 7 years ago with a euro ford engine and it was a real screamer... I don't even want to think what a f20 w/sc would do... BUT, the looks on the faces of the guys driving the big V8's would be priceless. lol
starrman is offline
Doug3
23
10-16-2012 07:40 PM
Doug3
33
10-15-2012 05:04 AM
playingmilitary
11-19-2008 03:31 AM
surfer
04-05-2008 09:41 AM
S2KsRGR8
07-26-2006 11:46 AM
Quick Reply: Did the timing jump?
