Vibration/rattle at low rpms
Old 07-18-2012, 05:36 PM
Hi All. I've noticed a vibration and rattle at low rpm. It sounds almost as if an exhaust bracket is loose but my mechanic says that the exhaust seems ok. When I increase the rpm the vibration and noise goes away.The car is doing about 109km (about 68thou miles.) any suggestions?
Carguy is offline
Old 07-18-2012, 06:19 PM
i think that the header heat shield is know to come loose and rattle.
how low are the rpm when you get the vibe?
if you don't give her enough gas from a dead stop, she will vibrate / shudder. you coming off the line at 1500 to 2000 rpm?
bbcricketta is offline
Old 07-18-2012, 06:31 PM
Thanks BB. I'd say about 1500; nothing too dramatic. I will have a look at the header shield.
Carguy is offline
Old 07-18-2012, 07:35 PM
House of CR.
Vanishing Point's Avatar
+1 on the shielding either at the header or the Catalytic convertor.
Vanishing Point is offline
Old 07-18-2012, 09:09 PM
official newb
kreapin's Avatar
x2 on header heat shield
kreapin is offline
Old 07-18-2012, 11:12 PM
Master Debater
Gadgetmanconnor's Avatar
Check your exhaust bearings. Sometimes a bearing can break and restrict exhaust flow and cause an annoying rattle.
Gadgetmanconnor is offline
Old 07-19-2012, 04:05 AM
'Jus' hadda heat-shiel' start makin' noize on Stewie too CG.
'D'put my money on'da shiel' too.
Java Junky is offline
Old 07-19-2012, 05:24 AM
House of CR.
Old 07-19-2012, 06:33 AM
Old 07-19-2012, 07:41 AM
House of CR.
Thanks for the reminder Switchblade, I'm almost out of blinker fluid.
Old 07-19-2012, 07:45 AM
Glad I could help!
Old 07-19-2012, 11:33 AM
Thanks all. Will definitely have a look at the heat shield. Appreciate the advice.
Carguy is offline
Old 07-19-2012, 11:41 AM
Gagetman, thanks as well for the information on the exhaust bearings. While I'm looking into that , I also plan to check the phase inducer for the warp energizer conversion matrix. That has been known to work loose from time to time.
Carguy is offline
Old 07-20-2012, 06:56 PM
JDMricist's Avatar
If it's not a heat shield then check your spark plug cover. It is metal and when it rattles, sounds just like a heat shield.
JDMricist is offline
Old 07-22-2012, 10:20 AM
Problem solved. A bolt had worked loose on the lower heat shield. Thanks for the help advice everyone.
Carguy is offline
Old 07-23-2012, 06:10 AM
Glad it was an easy fix!
Old 07-29-2012, 02:23 AM
Oz S2K
okeles's Avatar
muffler bearing ???? what the heck is that???
I really have to stick on the originals...
wow we don't know anthing about the mufflers....
okeles is offline
MattYielding
24
03-13-2018 01:26 AM
TygerRawR
05-28-2010 11:58 PM
Plucky J
04-15-2009 12:00 PM
jray8
16
10-07-2007 06:53 PM
AnthonyPearson
06-21-2005 10:50 AM
Quick Reply: Vibration/rattle at low rpms
