Changing the transmission fluid
Old 07-09-2012, 05:36 AM
Hi All. I'm thinking about changing my transmission fluid for the first time. Onlu recently got the car so I don't know what has been done in terms of service. It's doing about 68000 mls. A friend recommended Royal Purple syncromax. Any opinions? How much fluid does the S2000 gear box require?
Carguy is offline
Old 07-09-2012, 05:51 AM
that purple stuff is probably ok but i think you are just throwing money away. i have had good service with the honda mtf. pretty cheap too at http://www.handa-accessories.com/
the transmission holds just under 2 quarts. easy job. i have never understood why the dealership charges so much just to drain and fill the trans with $10 worth of fluid.
royal purple synchro is $22 a quart on e-bay. lotta profit built into that one. must have some gold in it.
Last edited by bbcricketta; 07-09-2012 at 05:54 AM. Reason: saving up for some royal flush purple wallet wash...
bbcricketta is offline
Old 07-09-2012, 06:38 AM
Thanks for the advice. I'm just new to the car and want to treat her well but if you've had good experiences with the Honda MTF then I'd definitely give that some serious thought. Didn't realize that Royal Purple made gold
Carguy is offline
Old 07-09-2012, 02:41 PM
LTWU's Avatar
i was happy with the honda mtf, but then switched to the royal purple syncromax. WOW, worth every penny. it's going in my CR and my wrx soon
LTWU is offline
Old 07-09-2012, 02:44 PM
Banned
i actually agree with LTWU. you can really tell a difference with royal purple syncromax. i'll never switch back to the cheap honda mtf. once you go purple, you cant go back, haha ha ha! the fluid is cheap, compared to the labor, so just make the switch. It's like, why would you use conventional motor oil when you can use synthetic?
BBFS for me is offline
Old 07-20-2012, 07:04 PM
JDMricist's Avatar
If you are going to dump that much money in trans fluid, go with Amsoil.
JDMricist is offline
Old 07-20-2012, 07:11 PM
Honestly.. Go with the Pennzoil SyncroMesh. Find it at your local auto parts store. $6 a qt. I've ran the Royal Purple... Amsoil... HONDA MTF... The Pennzoil SyncroMesh works better than the Honda MTF(This is coming from a Honda technician for 8yrs now) Works the same as the Royal Purple and Amsoil( Minus the big $$$ ).
Good Luck Sir..
-STG
SoftTopGuy is offline
Old 07-21-2012, 08:35 PM
Thanks for the recommendations. Already bought the royal stuff and will be making the switch tomorrow.
Carguy is offline
Old 07-21-2012, 10:03 PM
LTWU's Avatar
cool let us know what you think. didn't notice the difference at first, but after 15-20 miles . . . pretty awesome
LTWU is offline
Old 08-05-2012, 11:25 AM
Absolutely agree with you. Engagement seems smoother and certainly quieter. Expensive but worth it I think.
Carguy is offline
Old 08-16-2012, 11:54 AM
fr3sh2k's Avatar
I used 2 quarts of Honda authorized transmission fluid...I was kind of scared to venture outside the box. I can say that I do use syncromesh trans fluid on my turbo civic and it made a night and day difference.
fr3sh2k is offline
Old 04-16-2016, 08:01 PM
Got S2000?
Changed the fluid in the transmission and differential today, as it was a bit overdue and certainly nice enough outside to do it.
The diff went as easy as it usually does, but damn...those bolts on the transmission would not break! In my memory of doing this a few times before, these plugs have always been a bitch, but today just seemed absurd. After a short but strenuous effort, I was no longer in a mood to deal with it.
So, I finally found a great use for a scissor jack. Worked like a charm...I highly recommended it if you ever have the same trouble.
Jim21680 is offline
Old 04-17-2016, 05:43 AM
Pretty clever Jim. My only comment would be I would certainly want to use it with my body outside the perimeter of the cars' body. If the tranny bolt is that tight the car might come off the jackstand before it broke loose and then as it drops back onto the stands falls to the ground. Being smashed by your S will ruin your day.........
cdk456 is offline
Old 04-17-2016, 07:28 AM
Got S2000?
The jackstands stayed in the shed for this job; I decided to simply drive the car's two left wheels onto a couple of short 2x8's, stacked atop one another. Since I'm parked on a crowned street, this makes the car almost perfectly level, and gives me "just" enough room to get under the car. The break point for the bolts was very easy; just a slight "ping" without much drama.
Although next time I do this, I'll likely add a 2x8 at all four corners, to give me a little extra room for a breaker bar (which hopefully won't be needed).
Or, just use a nice flat garage floor and jackstands...
Jim21680 is offline
Old 04-17-2016, 01:27 PM
2009 Rio Yellow/A7E/A330
cosmomiller's Avatar
Was a clever idea.
I wind up changing the diff and transmission every spring. (Because I can!) Guess it keeps the bolts from becoming frozen in place as I certainly torque them to the correct values. I also drive the front end up on 2X6s so I can slip my Costco jack under the lip and put the thing on 4 jack stands. Then my anality takes over and I wind up wiping various parts underneath of the road dust so it looks all nice in places no one will ever see until I look again next year. Perhaps the fact my garage is carpeted in nice indoor/outdoor carpet makes it fun to crawl around. (The carpet came out of a legal office redo my builder was doing so I did my shop and garage wall to wall. Really keeps the house clean from me and the dogs too)
cosmomiller is offline
Old 04-17-2016, 02:45 PM
One of the downsides with the S is the front end is soooo damn low I can't get the floor jack under it. My fix was to buy a 2x12x8', I cut two 30" pieces and two 18" pieces, I overlayed the shorts on top of the longs and then drew a line from the high point 12"s in to the low end and used a circular saw to cut the wedge. That gave me two 3" wood ramps, just enough to let me get the floor jack under the front when I want to get her up for oil changes, which I will be doing next weekend.
cdk456 is offline
Old 04-17-2016, 03:54 PM
Got S2000?
CDK, you cut a 2x12 diagonally with a circular saw?!? Unless I'm missing something, I can't imagine how you did that!
Jim21680 is offline
Old 04-17-2016, 05:38 PM
do it from both sides then use a crosscut handsaw to cut the middle section the circular saw can't get to. Of course if I had a 12" circular saw I could have done it in the two passes...........
cdk456 is offline
Old 04-17-2016, 06:37 PM
I used my De Walt crosscut to angle the leading edge of 2 2X6s about 2' long. I only use then for the front wheels. Plenty of width for the tires. Just enough for jack clearance to reach the center engine jack point. When I am done, I back up to remove the wood. I have a little rolled duct tape to make them not slide when I drive up.
Old 04-18-2016, 04:17 AM
I tacked a piece of 1x2 across the front to keep me from rolling over the front edge. Back end if fine, you have plenty of room to get the floor jack under the diff.
I'll take a pic when I do the oil change later in the week. This afternoons job is to replace the carpeted 2x4 bunks on the jet boat trailer--------a job I have been putting off.
cdk456 is offline
Old 04-18-2016, 05:08 AM
Nice Jim!
Old 05-03-2016, 11:09 PM
axeler8's Avatar
Pretty cool trick using a jack Jim, especially working under the car.
axeler8 is offline
Old 05-04-2016, 03:11 PM
  #23
I always use Honda transmission fluid.
mcdavidbranson is offline
Maxipads
32
04-06-2011 09:05 AM
sraccord01
02-08-2011 11:35 AM
Jbeni96
13
10-26-2010 11:36 PM
marksrice
03-15-2008 08:20 PM
crazwhiteboy
11-08-2007 06:20 PM
Quick Reply: Changing the transmission fluid
