Will running e85 hurt my motor?
Old 06-10-2012, 10:11 AM
BBD324's Avatar
I was doing some research and found that e85 increases performance, is beneficial to the engine as far as keeping it in good shape, and has cleaner emissions.
The only downfall that i found out was the mpg's arent that great and i will be spending more $$ on fuel.
The S says "premium" only so i was wondering if anyone had any experience/ knowledge about this fuel and if it would still maintain my motor without causing any damage to it considering it isnt "premium"
Increased performance and having a healthier engine I will be willing to have by spending a little more at the pump. Thanks!
BBD
BBD324 is offline
Old 06-10-2012, 10:43 AM
TheCarGuy2021's Avatar
I would highly advise you against doing so until you can educate yourself a little more about E85. There are a few threads on this site discussing it. In a nutshell, if your engine is stock or near stock (not boosted without an upgraded fuel system and full standalone EMS) don't even think about it.
Do not, I repeat, do not go fill your tank with E85 if you have a stock car, you will destroy it in no time.
TheCarGuy2021 is offline
Old 06-10-2012, 11:23 AM
flyingarmadillo's Avatar
From the Honda Owner Link website FAQs:
"Fuels that exceed the EPA's approved oxygenate percentages for conventional and reformulated gasolines must be clearly labeled on the pump. One example of such a fuel is "E85," which contains 85% ethanol. Do not use such fuels in your vehicle. These fuels will cause performance problems, and may damage your vehicle's engine, fuel system, and emission control system. This damage would not be covered under warranty."
flyingarmadillo is offline
Old 06-10-2012, 10:22 PM
philiam is offline
Old 06-11-2012, 05:49 AM
TTMartin's Avatar
The S2000 ECU is not tuned for E85. If you have an aftermarket ECU or a 06+ ECU the S2000 could be re-tuned to run on E85, but, then only E85.
TTMartin is offline
Old 06-11-2012, 03:55 PM
BBD324's Avatar
I think this video answered my quesstions pretty well. lol
Thanks for all of the replies. Is e85 ever good for the motor?? Or is premium always the best way to go?
BBD324 is offline
Old 06-11-2012, 08:51 PM
Thanks for all of the replies. Is e85 every good for the motor?? Or is premium always the best way to go?
The best is to follow the manufacturers recommendation. Premium is a waste of money, and in some cases bad for your engine, if the engine is designed for regular. Premium has a higher flash point and in some situations can foul the plugs and leave more deposits in your engine from unburned fuel. If you're concerned about the environment then it's a bad choice in a vehicle designed for regular because of the increased emissions.
Old 06-11-2012, 09:34 PM
Follow Honda's recommendation. The car will run on regular but you'll lose
performance and mileage. It's a high compression engine.
philiam is offline
Old 06-12-2012, 03:50 AM
TTMartin's Avatar
The S2000 is NOT designed for REGULAR!
HONDA specifies PREMIUM FUEL for the S2000 due to its volumetric efficiency* and high compression engine. Using regular fuel in an S2000 can damage the engine.
*The volumetric effciency of the S2000 is over 100%
TTMartin is offline
Old 06-12-2012, 07:42 AM
Hybrid Hater
0tyrael0's Avatar
Im not sure if thats accurate. I dont see any reason for not putting premium in any vehicle (unless the manufacture specifically forbids it).
0tyrael0 is offline
Old 06-12-2012, 08:03 AM
agski's Avatar
Here's a link defining volumetric efficency. I thought it interesting!
http://en.wikipedia.org/wiki/Volumetric_efficiency
agski is offline
Old 06-19-2012, 02:29 PM
timmay208's Avatar
E85 is sweet if your tuned on it, but DO NOT run it in a vehicle that is not setup for it, you will run extremely lean and that can easily blow something up
Generally with E85 you need about 30% more fuel to get the correct AFR. So with e85 say at 3.00 a gallon vs premium at 4.00 a gallon its gonna equal to be about the same as your fuel mileage on e85 will suffer a little
timmay208 is offline
Old 10-11-2018, 09:43 AM
I beg to differ... While I do not have an S2000 I have a stock truck from 2004 and I shove E85 through it. While it is true it does lean out on the higher end of the RPMs it takes about a day for the ECM to compensate and bring the AFRs to about 13.5-14.3 and will touch 15.0 the first day and on the high end of Rpms if not careful can touch 16.0-17.0 so you gotta watch out for a day. I do get better lower end torque not much but a little noticable. In WOT it stays pretty rich but I believe it's like a 9.0-10.0 afr for E85 but running with it at 14.3 ish for a couple months so far hadn't hurt anything and seems to be just fine.
Kja4588 is offline
Old 10-12-2018, 07:30 AM
2009 Rio Yellow/A7E/A330
cosmomiller's Avatar
Nothing like bringing a thread back from the dead-11 years!
However, it is timely because the administration is about to loosen up federal rules on ethanol limits. We could be seeing a lot more 15% ethanol fuel in the future.
This places a lot of auto warranties out of business; E85 voids many warranties. Ethanol has been demonstrated to negatively affect rubber seals, hoses and the like that are not made for high ethanol content.
cosmomiller is offline
Old 10-12-2018, 07:47 AM
Didn't know it was 11 years old... But E85 does not do much in terms of fuel system damage considering you aren't letting your fuel system sit and bath in the E85. Most if not all modern cars have replaced rubber hoses with nylon type plastic and metal that have compression fittings that almost erases the use if rubber hoses and seals.
Kja4588 is offline
Old 10-12-2018, 07:48 AM
The thread is also only 6years old from time of last response. Just thought to clarify that.
Kja4588 is offline
bbcricketta
03-11-2013 07:29 PM
18
03-21-2011 05:54 AM
tsturbo
18
05-07-2009 11:02 PM
Tim Gedney
01-20-2007 05:03 PM
Quick Reply: Will running e85 hurt my motor?
