"Clicking" noise on starting roll/turns/reverse
Old 05-26-2012, 05:59 AM
hear a single "click coming from what sounds like the rear or poss wheels/drive axle/diff of my ap1. have not been able to isolate it. It sounds OK other than this single click. I am new to this car but familiar with various noises as I also have an 07 ap2 that I have owned since it was new. Can anyone speculate as to a possible origin of this noise or what to check? I am afraid it might be signaling a future problem. The car sat for a long time, (almost 3yrs) so anything is possible. I have driven it now for a month and the sound does not get worse but is still present. Thought of brake calipers and ruled that out
white pearl is offline
Old 05-26-2012, 07:12 AM
Never Slow down
Wayne's Avatar
My first thought would have been the calipers, when do you hear it?
Wayne is offline
Old 05-26-2012, 07:20 AM
hear this on clutch release going forward or reverse but not related to transmission or clutch. definetly coming fronm the rear. Discovered yesterday when I put new tires on that a rear rim was slightly bent. Now thinking it might be a drive axle but so far no other symptoms have evolved.
Old 05-26-2012, 07:25 AM
differential checked out when I changed the oil with Royal Purple. It sounds fine. Are there universal joints that might do this? I do not hear a clank when the clutch engages
Old 05-26-2012, 07:47 AM
House of CR.
Vanishing Point's Avatar
If the click is audible especially when backing I would say rear axle nut(s). Let me see if i can find you a post on how to DIY rather than me give a lengthy post.
Found it.
http://www.s2ki.com/s2000/topic/9298...e-nut-tsb-diy/
Vanishing Point is offline
Old 05-26-2012, 07:56 AM
Party Rock Crew
starrman's Avatar
axle nut
starrman is offline
Old 05-26-2012, 08:35 AM
That link with pictures was incredably helpful and makes sense. I am going to check it out today and will get back....that sounds like it might be the problem. Also will be looking for one replacement rim. If I remember from my past there are places that straighten & true out rims..may check on that. Thanks for the helpful post vanishing point.
Old 05-26-2012, 12:11 PM
burlys2k's Avatar
+1 axle nut.
burlys2k is offline
Old 05-26-2012, 06:48 PM
TTMartin's Avatar
Originally Posted by starrman View Post
axle nut
+2
TTMartin is offline
Old 05-27-2012, 09:03 AM
Had same problem switched axle nuts from right to left and retorqued = all better no more clicking.
jtsimaras is offline
Old 05-27-2012, 09:16 AM
House of CR.
Curious why you felt it necessary to switch axel nuts?
Old 05-27-2012, 10:20 AM
Axel nut for sure just torque them down or get new ones and tighten them properly
kingstarlet is offline
Marioshi
44
06-30-2012 01:13 PM
s2k01
8
10-03-2009 08:42 PM
moos500
09-28-2009 09:42 PM
s2k01
18
10-26-2007 04:05 AM
wallc777
9
06-20-2006 06:40 PM
Quick Reply: "Clicking" noise on starting roll/turns/reverse
