clutch squeaks when depressing
Old 02-24-2012, 07:50 PM
Hi guys, i'm new here and am a proud owner of an 03 s2k.
I bought it used of course.
When i first purchased the car i did not hear the clutch squeak.
Several days later after driving it for 45 minutes in the city, i pulled into my garage and was easily able to hear the clutch sqeak when depressing it.
I can hear it inside the cabin and also loudly outside the car (things are louder in the garage since all sound is reflected).
Clutch seems to operate normally and grips well.
I'm a noob at cars and forums. Please help! thank you!
Ech0 0ne7 is offline
Old 02-24-2012, 08:19 PM
mlc
mlc's Avatar
Here is a good thing to try first http://www.s2ki.com/s2000/topic/3707...-clutch-pedal/
Kevin
mlc is offline
Old 02-25-2012, 11:02 AM
Old 02-25-2012, 12:57 PM
House of CR.
Vanishing Point's Avatar
He's squeaking because he's hungry.
Vanishing Point is offline
Old 02-25-2012, 01:19 PM
rattpak's Avatar
Yep. Sounds like it's completely done for. I'll start the bidding at $100. Let me know if you prefer cash or money order.
rattpak is offline
Old 02-27-2012, 05:23 AM
Seriously though, do what Kevin posted and let us know how you make out.
Old 02-27-2012, 11:51 AM
project ap2's Avatar
yeah let us know how it goes..it hear it once in a while when im about to start the car...
project ap2 is offline
Old 03-01-2012, 01:28 PM
Thank you guys!! On my next off day, I will get to work! Seems like a easy fix. Can anyone loan me a dremel tool? .
Will the dremel scare the hamster away faster?
I'll keep you up to date after the fix.
Thanks guys.
Old 03-06-2012, 06:32 PM
I did what that link said to do.
It worked. thank you guys so much.
I couln't get it to a mirror shine, but i used the finest sant paper and a occilator to smooth all the roughness out and tried to buff it with a microfiber towel on the occilator. ehhhh.
In the end after grease and reassembly, the sqeak is gone.
Clutch feels smoother and easier to depress when shifting 1st to 2nd, 2nd to thrid, etc,
but at a dead stop to first, clutch feels harder to depress and feels rougher.
any thoughts?
Old 03-06-2012, 06:43 PM
AP1S2000's Avatar
It might be your master cylinder. Does the fluid get dirty quickly? Check for a leak coming from the cylinder by the pedal. What kind of grease did you use when re-greasing the slave?
AP1S2000 is offline
Old 03-06-2012, 07:16 PM
mlc
mlc's Avatar
Feel the carpet under the clutch pedal and on top of the dead pedal. If you feel brake fluid then the clutch master cylinder is leaking. Also look at the piston that the clutch pedal connects to, look around the shaft that goes into the cylinder and if it is "wet" then it could be drawing air into the system as well.
Start off bleeding the system and see if that helps http://forums.s2kca.com/showthread.p...ch-fluid-bleed.
If it is leaking for sure then change the master cylinder http://forums.s2kca.com/showthread.p...-How-To-Change . You can buy one at cflhonda.com for $85 plus shipping at least that is what mine cost.
Good luck.
Kevin
mlc is offline
Old 01-01-2013, 10:16 AM
Chief Hata in Charge
Thanks MLC. I just drove my car to Houston and back (700 miles) and on the way home my pedal started to squeak and the pedal was a little soft.
Sure enough, I felt the carpet and my fingers were coated with grease and brake fluid. I will order a new master cylinder and get this thing swapped.
yashooa is offline
Old 01-02-2013, 05:42 AM
Holy crap, it's Yash! How ya been man?
