Full valve job advice due to mechanical over rev
Old 10-12-2011, 08:07 PM
Hey guys. I'm looking at doing a full valve job myself and would appreciate any advice from the community.
It's been a long time coming so I'll give you a little history. I've got a 2004 S2000 with the F22C. I've had it since new. It's got around 70k on it now. I'm pretty sure I've hit the money shift at least once (if not more) in the past. A couple of years ago I started getting all the misfire codes. I originally thought it was the MAP sensor issue. I did the MAP whack, cleaned the passages (which helped the idle), added the zip tie, even installed a new MAP sensor with the zip tie all to no avail. After that I started reading all the pages about mechanical over revs from a missed shift and the related cracked retainers, bent valves, etc.
Last year in an attempt to pass inspection I finally did a compression test. Cylinders 1, 2, and 4 were all around 240 psi. Cylinder 3, however, was only at 190 psi. It was also full of black deposits. I performed a valve adjustment at that time. Unfortunately I did not write down all the measurements. I do remember that just about everything was tight. Some were at no clearance. I tried looking to see if any of the retainers were cracked but did not understand as much at the time what to look for exactly. (I know most the cracked retainers have been on the F20's but I'm still suspect of it since everything was so tight.) After that all the codes cleared and have not returned. The car has ran much better as well. Since I'm still concerned about dropping a valve I haven't gone over 4k rpm in the last couple of years (which has sucked by the way).
So now I've decided to fix it for sure. First I'm planning on doing a leak down test just in case that tells me anything new. I figure if I'm going to pull it apart I might as well go ahead and replace everything. I'm planning on pulling the head and installing new valves (intake and exhaust), guides, seals, keepers, springs, retainers, and seats. I've read that it's hard to beat OEM for the valves. Any reason to go oversize? I've read that you can actually lose airflow in the VTEC engines with oversized valves. I was thinking of going with Supertech guides.
As far as springs I haven't decided. I definitely do want to go aftermarket. There's Supertech, Ferrea, Skunk2, Spoon, Brian Crower, ScienceofSpeed, InlinePro, and more I'm sure. Any advice would be greatly appreciated. What about dual springs? What about titanium retainers?
What about gaskets? I assume I'll need a cylinder head gasket, an intake gasket, and an exhaust gasket. I read that Honda has a full kit but I haven't seen it anywhere. What about the Hondata heatshield gasket?
My other big question is about what to do with the head itself. I guess I need to send it out to a shop to check if it's warped and needs resurfacing. I've read that a basic three-angle valve job is the best bet. Any thoughts? I've also read that porting and polishing an S2000 head doesn't get you much. Should I send the whole thing off and get them to remove and install everything? Does anyone know any good shops in the Dallas area? I've found these shops online but don't know much about them: City Motor Supply in Dallas, ENDYN in Fort Worth, Ballade Sports in Garden Grove, Speed-O-Motive in West Covina, HP Engines in Norwood, Performance Porting in Loveland, Port Flow Design in Harbor City, and CC Cylinder Heads.
Should I get new head bolts? I know the service manual gives bolt diameters to check for stretch. I think the ARP kit is $150. Necessary?
I found a couple of good write ups that may be useful to others as well. One from modified and the other from Honda Tuning.
http://www.modified.com/projectcars/...000/index.html
http://www.hondatuningmagazine.com/t...ild/index.html
I'd appreciate any help you guys can offer. I know this is a lot of info and a lot of questions but I've been mulling this over for a while. I know there's lots of posts on this topic (because I've read all I can find) but I haven't seen any that discuss everything done to fix it. I've got the service manual and would rather buy any tools needed over paying someone else to do it. I just want to know what I need before hand. I'd like to have all parts ready to go before I rip it apart. Thanks again.
agthad is offline
Old 10-13-2011, 05:45 AM
s2000isu's Avatar
Honestly sounds like a huge waste of time and money to me. Good luck
s2000isu is offline
Old 10-13-2011, 06:16 AM
Why wouldn't you just go all OEM again. There was nothing wrong with the original design. that is just my 2 cents though.
crossracing70 is offline
Old 10-13-2011, 06:17 AM
s2000isu, Any particular reason? Do you not think there is valve damage?
agthad is offline
Old 10-13-2011, 06:19 AM
crossracing70, I've read that aftermarket springs are stronger than OEM so they resist valve float better.
agthad is offline
Old 10-15-2011, 11:44 AM
Has anyone had this head port and polished? Notice a difference?
agthad is offline
Old 10-18-2011, 07:23 AM
bump. Anyone else have any suggestions?
agthad is offline
Old 10-18-2011, 09:45 AM
If you are going to do this it is your choice. If you have bad compression it could be bent valves creating blow-by which would be the reason to redo the head. I would take the head off and check the bore of each cylinder and if the cylinders do not look scoured I would continue with getting the head done. Just remember to do a compression test before and after the repair. Aftermarket parts a generally stronger and usually cheaper or the same price as factory. I would go aftermarket.
littlebuff is offline
Old 10-18-2011, 01:18 PM
Thanks littlebuff
agthad is offline
Old 12-11-2011, 06:42 AM
I rechecked compression and did a leak down test yesterday. Compression came out the same as before and the leak down showed expected results.
Cylinder...........Compression (psi).........Leak Down (%)
....1.....................240..................... 10
....2.....................240..................... 20
....3.....................190..................... 45
....4.....................240..................... 5
The leak down in 3 sounded to be both in the intake and exhaust.
I've purchased all Supertech components for the rebuild (valves, guides, seals, springs, spring seats, retainers, keepers). I'm taking the head into Watt's Engine Shop next week. I can't wait to get this baby back to how she should be. I've got the Honda gasket kit, crush washers, fluids, spark plugs, K&N air filter, everything I could imagine I'll need to get back up and running. I'll let you know how it goes. I'll take plenty of pics.
agthad is offline
Old 12-12-2011, 07:30 PM
Banned
supertech is very good quality, I am building an H23 head with it right now. The Viton exhaust seals are the best.
Make sure you have that head machined and tanked.
berlinas2k2 is offline
Old 12-13-2011, 07:20 AM
I'm taking the head to Watt's to be machined. What do you mean by tanked?
agthad is offline
Old 12-13-2011, 07:23 AM
Are you talking about a hot tank to clean it?
agthad is offline
Gadgetmanconnor
39
08-08-2012 01:22 PM
Bear Down
12
07-03-2012 05:05 AM
Xiaoschi
26
04-05-2012 09:36 PM
P.O.L.A.R
35
11-08-2010 09:13 PM
SORS2000
11
07-06-2009 01:53 PM
Quick Reply: Full valve job advice due to mechanical over rev
