Redline Trans Fluid... MT90?
Old 09-20-2011, 05:48 PM
9524tee's Avatar
Exclamation Redline Trans Fluid... MT90?
Hey peoples... I just got an S2000... 2002 with 100k miles and I wanna swap all of the fluids with top notch stuff to keep it happy. So.... I have 3 quarts of Redline Synthetic MT90 manual transmission/transaxle fluid laying around that I never used. Will it work and be any better than OEM fluid? I just don't want to waste my time or possibly hurt my transmission. This was recommended for my old Integra but I never got to put it in before I sold it...
Also, does the S2000 have a sealed system like my 2008 Honda Civic does? I was told if it's sealed I can't put aftermarket fluid in? ::: Confused :::
Thanks guys... I searched but didn't see anything specific...
9524tee is offline
Old 09-20-2011, 05:51 PM
what weight is the fluid you have on hand?
jagg is offline
Old 09-20-2011, 05:56 PM
lolz,
ain't never seen a tranny without some kind of vent, or a pumpkin, nor an engine.......
So, your civic was an automatic trans?
jagg is offline
Old 09-20-2011, 06:20 PM
9524tee's Avatar
The civic is a manual 5 speed.
The back of the bottle says, " MT90 meets gear oil viscosities SAE 75, 80W and 90, or motor oil viscosities, SAE 40 and 10W40 and provides gear protection which satisfies API categories GL-1, GL-3 and GL-4. It also says " This product is not designed for use in a rear wheel drive differential, which requires a GL-5 lubricant.
I've only worked on older imports so I'm doing my research before I start messing crap up. I want to do it right, or not at all.
9524tee is offline
EVL Member
Use Honda MTF or GM syncromesh
EVLS2K is offline
Old 09-20-2011, 06:22 PM
EVL Member
2 quarts , it takes less than that like 1.75
EVLS2K is offline
Old 09-20-2011, 06:33 PM
9524tee's Avatar
Honda MTF is going to be better than the MT90 then?
9524tee is offline
Old 09-20-2011, 06:47 PM
yes.........the fluid you have on hand is too heavy.
honda mtf.
jagg is offline
Old 09-20-2011, 07:36 PM
9524tee's Avatar
Good to know, thanks a lot.
9524tee is offline
Old 09-20-2011, 10:28 PM
MTF is made for the Honda transmission. Why try something else to save a few bucks. It's recommended to use Honda coolant as well.
philiam is offline
Old 09-25-2011, 10:01 PM
9524tee's Avatar
Well I'm asking because it could possibly be superior due to it being a great product and being synthetic? This is why I asked. But if everyone says the Honda MTF is the best then I'll just go with that. It would be stupid of me to just throw it in without at least asking if the 25 dollars of fluid I have laying around might be good.
9524tee is offline
weigle54
10-06-2008 07:20 PM
AeroS2000
16
08-04-2008 02:30 PM
matt3542466
01-29-2008 12:31 PM
DMC_S2000
01-18-2007 10:46 AM
DMC_S2000
06-24-2006 10:33 PM
Quick Reply: Redline Trans Fluid... MT90?
