Small metal knocking sound from my motor !!!!! Ahhhhh >
Old 06-01-2011, 07:35 AM
So hears the scoop 2001 s2k 66900 on the odo 4k sence the last oil change mobile 1 and I was taking part in some high speed fun tonight. Long story short, after this on the way home I started hearing a ticking I have a vid up now to show and hear the sound. You can really start to hear what I am talking about 1:14 or so seconds in. I plan to drain oil tomorrow and cut the filter down to inspect. The check engine light is on from the cat mod and yes I just checked the code now still the cat but the sound is 100% internal motor. Does not make a difference if it is in neutral or driving same problem can't hear it tell 2300 rpm or so and only under a load and idle at 3000 rpm above that if you spike it to 5000 or any thing above 3900 and are off the gas the sound is gone ..... Pleas help!!! I am planing a compression test tomorrow before the oil change..... Thanks to all the good help from this forum !!!
Video link
http://m.youtube.com/?client=mv-goog...user=weldabike
Weldabike is offline
Old 06-01-2011, 08:52 AM
House of CR.
Vanishing Point's Avatar
When was the last time you adjusted the valves? Sounds like it may be the issue.
Vanishing Point is offline
Old 06-01-2011, 10:31 AM
doesn't sound like a rod or bearing. maybe a valve retainer? have they been changed out? maybe one has cracked as they are known to do in the early AP1s. have the banjo bolts been changed out--probably not related to this noise but if they haven't been changed, you need to do it--another AP1 problem.
bbcricketta is offline
Old 06-01-2011, 01:50 PM
I have only had the car for about a year its a salvage title so I dont know about much history nuthing of the motor .... Tell me more about the ap1 problem ... I dont think I would ever sell this car I love it far too much
Old 06-01-2011, 05:14 PM
TheCarGuy2021's Avatar
Ever change the timing chain tensioner?
TheCarGuy2021 is offline
Old 06-01-2011, 07:50 PM
No do you think that is what the sound is ? As far as I know it has never Ben changed....??
Old 06-06-2011, 07:23 PM
Rod baring is spun on cyl 3 ........ Any one know of the best place to buy new ones that will last ??.
Old 07-06-2011, 02:54 PM
so what was the out come?
jolden is offline
Old 03-08-2012, 09:31 PM
any updates on this S?
S2Krazy21 is offline
agsanders
9
08-26-2014 04:29 AM
kikang
17
03-06-2012 05:33 AM
wdonahue0789
Wheels / Tires / Suspension
04-12-2011 07:42 PM
the925s
01-17-2011 04:52 AM
yashooa
20
12-24-2010 05:29 PM
Quick Reply: Small metal knocking sound from my motor !!!!! Ahhhhh
