Throttle cutoff?
Old 04-28-2011, 08:38 PM
addisonlewis1's Avatar
Question Throttle cutoff?
So today I was just driving a little, and I felt like having a bit of fun so I stepped on it in first gear, then I hit around 6000 RPM's, around VTEC, and the throttle just cutoff even though I was still holding down the throttle. I was just getting out of my neighborhood when this happened, so I'm thinking that maybe because it was when the engine was still cold?
ALSO; (I was having alot of weird mistakes driving today... ) Does my Ap1 2002 S2000 have a rev limiter???? Because I went into the redline today, and it scared me that I could've done something to the engine. (This was after the whole throttle cutoff thing happened, the engine was warmer)
addisonlewis1 is offline
Old 04-28-2011, 09:20 PM
tehboxzor's Avatar
I know the AP2's have a 6k rpm cutoff if the engine doesn't have at least 3 bars on the temp scale.
I heard AP1's also have the 6k rpm cutoff if the engine hasn't reached a certain number of bars also....Just not sure how many bars.
tehboxzor is offline
Old 04-28-2011, 09:40 PM
Master Debater
Gadgetmanconnor's Avatar
i guess your screwed if your thermometer goes out!
Gadgetmanconnor is offline
Old 04-28-2011, 11:12 PM
Revving up a cold engine is a good way to shorten it's life. The majority of engine wear occurs when you start up. When the car is warmed up taking it to red line is fine. That's why the cutoff is there.
philiam is offline
Old 04-29-2011, 02:41 AM
The car will not go into VTEC when it is cold. It does exactly what you described. The throttle essentially cuts off the gas. It's designed to keep people from doing damage to the engine. I don't know about the AP-1, but the AP-2 has a over-rev limiter (for acceleration only. If you're driving 65mph and decide to shift to 1st, you might plan on looking for a new engine because there's no over-rev limiter for stupidity ).
Old 04-29-2011, 05:25 AM
AP1's won't engage VTEC until it is fully warmed up (3 bars) to protect the engine. Wait until you've warmed up to 3 bars then have fun.
Old 04-30-2011, 01:54 AM
Don't cross a magic rope!
griffon's Avatar
Originally Posted by kgf3076 View Post
The car will not go into VTEC when it is cold. It does exactly what you described. The throttle essentially cuts off the gas. It's designed to keep people from doing damage to the engine. I don't know about the AP-1, but the AP-2 has a over-rev limiter (for acceleration only. If you're driving 65mph and decide to shift to 1st, you might plan on looking for a new engine because there's on over-rev limiter for stupidity ).
And you just can't fix stupid, either.
griffon is offline
Old 04-30-2011, 11:29 PM
Bug Zapper
Marioshi's Avatar
Your S2000 has a rev limiter at 9200 rpm. Its ok to hit it occasionally, its there to keep you from over-revving it.
If you downshift into a gear too low for the speed you are going, you can cause damage.
Marioshi is offline
Old 05-02-2011, 04:43 PM
Phew. What a relief. I was afraid that something was wrong with my engine...
Old 05-02-2011, 05:45 PM
LOL!
RMurphy is offline
jackson38119
12-02-2007 07:48 PM
john
15
10-25-2007 07:41 PM
Elusive8S2k
8
10-07-2007 08:45 PM
Xman
06-23-2004 01:13 PM
Red
01-11-2004 03:53 AM
Quick Reply: Throttle cutoff?
