Going to replace Valve retainers
Old 06-10-2011, 10:31 PM
  #41
Hybrid Hater
0tyrael0's Avatar
Nope. All retainers that I have posted are cracked and from the exhaust side (save for the one on the far right. That one I just used as an example. I dont know what side its from.
0tyrael0 is offline
Old 06-11-2011, 02:28 AM
  #42
TTMartin's Avatar
Glad to hear you got them replaced in time!!!!
TTMartin is offline
Old 06-11-2011, 11:16 PM
  #43
Hybrid Hater
0tyrael0's Avatar
Me too! I just got it back today. It drives excellent. It might just be my mind playing ticks on me but I think I hear reduced valve noise after the repairs.
0tyrael0 is offline
Old 06-13-2011, 05:18 AM
  #44
Damn dude!! Good thing it's fixed!
Old 06-30-2011, 09:04 AM
  #45
Bug Zapper
Marioshi's Avatar
So, doesnt this go against everything that has been said? I thought the intake retainers were the ones that failed? Makes me wonder if yours was an independent issue...
Marioshi is offline
Old 06-30-2011, 10:50 AM
  #46
Originally Posted by Marioshi View Post
So, doesnt this go against everything that has been said? I thought the intake retainers were the ones that failed? Makes me wonder if your mechanic got the intake and exhaust sides mixed up
fixed.
turbosix is offline
Old 06-30-2011, 10:53 AM
  #47
Bug Zapper
Marioshi's Avatar
Originally Posted by turbosix View Post
fixed.
Could be. Id be worried about taking it to a mechanic that got that mixed up though. Any way to tell confrim T6? Difference in design perhaps?
Marioshi is offline
Old 06-30-2011, 11:09 AM
  #48
all the retainers & cotters are identical for ap1 intake/exhaust.
the ap2 are identical intake/exhaust but obviously a different design from the ap1.
if he's a normal honda mechanic i'm sure it'd be easy to switch it up since in most cases the motor he's working on would be mounted sideways
turbosix is offline
Old 06-30-2011, 11:26 AM
  #49
Bug Zapper
Marioshi's Avatar
Pretty good news either way for Oty that he got his replaced.
Marioshi is offline
Old 06-30-2011, 08:47 PM
  #50
Hybrid Hater
0tyrael0's Avatar
Nope he took pictures to show me. If he still has them I guess I could post them. You can see in the picture the exhaust valves are sitting a hair lower than the others. He was 100% sure they were exhaust valves.
I could very well be the only one that had broken exhaust valves. However they are broken.
0tyrael0 is offline
Old 12-11-2011, 09:01 PM
  #51
What was the mileage when you replaced yours?
ptown2000 is offline
Old 12-12-2011, 02:52 PM
  #52
TTMartin's Avatar
Milage doesn't matter. What matters is if the engine was EVER over REV-ed. The retainers can be cracked, and then just break at anytime (even during normal driving)dropping the valve into the cylinder.
TTMartin is offline
Old 12-12-2011, 04:56 PM
  #53
What are the signs? I know that taking the vc off and inspecting is not good enough. Is there any specific sounds?
Old 12-12-2011, 07:01 PM
  #54
rattpak's Avatar
Mine never made any different sounds and I had six bad ones on intake side.
rattpak is offline
Old 12-13-2011, 05:24 AM
  #55
Your best bet is to actually look at them. Check out this pic from s2ki:
Good one is on the left, bad on the right. See how the retainer on the right is working it's way down the valve.
Old 12-13-2011, 05:00 PM
  #56
Good one is on the left, bad on the right. See how the retianer on the right is working it's way down the valve.
Thank you so much that is great info and pics. Can I inspect them properly still on the car easily? With the combination of visible cracks added to my inspection?
Old 12-13-2011, 05:16 PM
  #57
It's her car
I think there is a camshaft in the way.
Bigal is offline
Old 12-13-2011, 07:11 PM
  #58
Banned
Pull the valve cover, and inspect the valve height near the keepers.
berlinas2k2 is offline
Old 12-14-2011, 05:12 AM
  #59
Should be able to. Once again a pic from s2ki. Good on the right, bad on the left.
Old 12-14-2011, 05:54 AM
  #60
I had all 16 of my retainers replaced this summer after dropping a valve. Luckily it did not drop into the cylinder, just bounced up and down against the cam shaft.
Anyway, I had four with cracks in the end but the thing is you cannot see the crack unless you take the retainers out as the crack is always on the underside and once you have done that you may as well replace them. Parts are cheap, but a few hundred in labour. With an AP1 I say its money well spent for piece of mind
VeryMetal is offline
Old 12-14-2011, 12:26 PM
  #61
TTMartin's Avatar
TTMartin is offline
Old 12-14-2011, 03:25 PM
  #62
I know the parts are cheap and I am scared that they are cracked for sure.
Has anyone on here done the job recently?
What do you rate the job personally in difficulty?
What is your background/experience on a car?
Old 12-14-2011, 03:26 PM
  #63
That is not definite to me...
I can barely tell which one is bad?
Old 12-14-2011, 03:34 PM
  #64
yes
pretty easy, but somewhat time consuming
very extensive.
you have to take your time to do it right. additionally, you should modify the spring compressor you get before you start. it can take awhile to get correct and it's pretty much impossible to do the job without cutting it up.
turbosix is offline
s2kpat
Parts For Sale
06-24-2013 09:12 AM
VeryMetal
27
09-21-2011 08:12 AM
AP1S2000
01-19-2011 09:40 PM
dts2000
05-28-2010 12:36 PM
TegoS2k
15
12-09-2008 11:10 AM
Quick Reply: Going to replace Valve retainers
