bleeding the brake and clutch fluids
Old 03-28-2011, 05:20 PM
Banned
my question is. i dont have the tools and time to bleed the brake and clutch lines. so. can i just use a syringe to suck the old stuff out from the resevior. add new fluid. drive around a bit, suck old stuff out and repeat a several times? is that good enough?
two faced rat bastard is offline
Old 03-28-2011, 06:42 PM
General Nuisance
Doug3's Avatar
No!
Doug3 is offline
Old 03-28-2011, 06:44 PM
why don't you bleed to death and suck this old stuff out?
bbcricketta is offline
Old 03-29-2011, 04:00 AM
TTMartin's Avatar
That actually works, I do it one time (repeating doesn't do anything) yearly, and have done so for many years on my vehicles.
It can actually be better on neglected systems, as all new fluid can cause seals to swell and fail.
Just be very careful, as brake fluid is a great paint remover.
The only time I bleed is when I change the pads.
TTMartin is offline
Old 08-21-2011, 07:56 PM
Got S2000?
Planning on bleeding the clutch soon. I've begun to notice a bit more resistance in shifting between gears, so I'm thinking (or hoping) that a trans & clutch fluid flush will solve this issue. The clutch fluid is original; 45,000 miles old. The trans fluid is about half that.
So, I'm planning on doing a simple gravity bleed on the clutch...has anyone else done this with success, or problems??
Jim21680 is offline
Old 08-22-2011, 07:19 AM
phins2rt's Avatar
I've done a gravity bleed with no problem! GL.
phins2rt is offline
Old 08-22-2011, 04:06 PM
gravity bleed, easy.
turbosix is offline
Old 09-06-2011, 01:35 PM
sp00led's Avatar
When bleeding the slave cylinder I found it helpful to put the drain hose in a half full bottle of fluid. I bleed it until the air bubbles stop. The hose submerged in fluid helps keep it from sucking up air in the process.
sp00led is offline
Old 09-26-2011, 08:29 PM
Got S2000?
Attempted to bleed the clutch today...not quite as easy as I thought. Didn't have the right size tubing (or jack stands, or a creeper), so I just stopped right there before I got too frustrated. The bleeder is in a horrible place. Can the slave be removed from the tranny to bleed it??
Jim21680 is offline
Glenn1
16
01-13-2011 11:49 PM
AeroS2000
18
11-18-2010 08:54 AM
phonedrn8
Wheels / Tires / Suspension
22
06-22-2010 07:14 AM
salthepalfromcal
15
07-07-2009 03:05 PM
Jessa1200
20
01-29-2009 01:08 PM
Quick Reply: bleeding the brake and clutch fluids
