newb with unfindable question
Old 03-18-2011, 09:32 AM
Hello, this is the first time posting on a forum so please forgive. I do not currently have an s2k but have been searching for one for a while. I found one, but i dont have much info on the engine problem but here is what he told me.
It starts normaly with no problem and you can rev the engine while in neutral but as soon as you put the car in gear you cant go much above 3-4k rpm's due to loss of power. he said that there is a knocking sound but im not sure if he said it upon startup or once in gear. I have a 2001 Lexus IS300 with 186,500 miles and a leaking head gasket. If i change the head gasket would it be worth a trade? he has a full megan exhaust with test pipe and it is lowered. he had it set up for drifting.
Thanks.
BrownPants209 is offline
Old 03-18-2011, 09:36 AM
That S2k is in limp mode (power cuts off above 3k so that you don't finish the job of destroying the engine that he started). Knocking sounds are never good. Do not hesitate, do not walk, RUN away from this. You'd be better off putting a head gasket in your car and saving to buy a car that hasn't been abused.
Old 03-18-2011, 10:27 AM
essstwokay's Avatar
Originally Posted by kgf3076 View Post
That S2k is in limp mode (power cuts off above 3k so that you don't finish the job of destroying the engine that he started). Knocking sounds are never good. Do not hesitate, do now walk, RUN away from this. You'd be better off putting a head gasket in your car and saving to buy a car that hasn't been abused.
+1!!!!
essstwokay is offline
Old 03-18-2011, 10:43 AM
Old 03-18-2011, 10:50 AM
Top Always Down
Dr. Jimbo's Avatar
One man's junk is another man's junk in this case. Keep lookin'. BTW, the S2000 is not a good drift car so if he was doing that, he probably beat the crap out of it.
Dr. Jimbo is offline
Old 03-18-2011, 11:36 AM
Party Rock Crew
starrman's Avatar
I would have to agree with everyone, RUN, he probably knows what he did..but is not going to tell you.
starrman is offline
Old 03-18-2011, 02:34 PM
Thanks everyone for your answers!
Thanks for the responses and not bein disrespectful about it! i was suspicious myself, but just wasnt sure. he said what the problem was but then said next, "but im not sure what the problem is"...im def walkn away!
Old 03-19-2011, 06:19 AM
There are good ones out there, especially in the spring.
gerry100 is offline
Old 03-19-2011, 11:01 AM
whitebrad25's Avatar
Everything mentioned above says it perfectly....except ess too yay...
whitebrad25 is offline
Old 03-19-2011, 11:05 AM
Being Hondas these things do not have to be coddled to endure.
Anyone who can damage one has worked pretty hard. Imagine what else wrong.
Plenty of good values out there to be found with patience.
gerry100 is offline
Old 03-19-2011, 01:42 PM
s2000isu's Avatar
Being its a honda lol. Ya these cars dont have any known issues no spark plug failure that trash the motor, the occasional rod that shoots out the side of the block for no real reason, tct's getting noisy, soft tops tearing prematurely, axle issues, shifters getting stuck in the reverse lockout, trouble getting into 5th when the car has sat for a long period of time shall I continue? Glad to see you know the ins and outs of our car and issues that people have had. All cars have problems even if its a honda.
They are normally pretty reliable cars the question is can you determine why the damage happened and is the price right where it makes sense for you to repair it.
s2000isu is offline
Old 03-19-2011, 02:25 PM
my guess is one of two things berings maybe or piston slap (less likely). the noise your hearing is probably there when you rev it in neutral it's just not very loud, when you put the engine under load it puts more stress on the crank shaft and more than likely its a bearing on the shaft to the block not the shaft to the rods. If it were the shaft to rods the noise would more than likely be constant regaurdless of engine load. thats my guess.
If its piston slap youll be putting out smoke from the exhaust (the rings have blown out if thats the case) as i said before less likely. really we need to hear the noise to help out better.
1TWISTEDTypeR is offline
Old 03-28-2011, 09:10 AM
Are you kidding ?
In that case, perhaps you could find and solve consequences, or luckier causes, but it will never tell every invisible injuries that occured in the past, with this bad using...
WTF he just don't want at all an abused S2K, the sailer has to deal with his own c...t.
At the end of your big restroom work, will you pay for used toilet paper ?
El Gato Negro is offline
Old 03-28-2011, 09:42 AM
Originally Posted by El Gato Negro View Post
Are you kidding ?
Détendez-vous mon ami. Il établissant une liste d'épicerie de choses qui «pourrait» être erroné. Il ne peut pas être sérieux.
Old 03-28-2011, 10:04 AM
Old 03-28-2011, 10:09 AM
yeah, you tell 'em KG........
relaxamundo Black Cat.
jagg is offline
Old 03-28-2011, 10:44 AM
Are you kidding ?
turbosix is offline
Old 03-28-2011, 11:11 AM
Je suppose que vous ne parlent pas français ...
Old 03-28-2011, 11:23 AM
I don't speak French.
brads-s2
26
11-09-2010 11:01 AM
mrhonda
03-19-2008 09:49 PM
EJ2-B16a
01-08-2008 08:21 PM
Shiftred Rocket
08-28-2007 08:07 PM
iranian45
05-03-2006 07:01 PM
Quick Reply: newb with unfindable question
