Oil pressure light on
Old 10-01-2010, 08:53 PM
"Easy come, easy go"
the.aviator2's Avatar
Question Oil pressure light on
Hi guys,
Since I changed my TCT few months ago, I noticed that every time I start the car in the morning, the oil pressure light stays on for a second longer than the other lights, but then it goes off. Also, when I leave the car for some time(like 15 min.) after driving it, when I start it after that, the red light flashes quickly like two times then goes off.
Any one can think of a reason why the light stays on more than usual? I also tried shaking the wires near the TCT, but nothing has changed.
Thanks in advance,
the.aviator2 is offline
Old 10-01-2010, 11:48 PM
Bug Zapper
Marioshi's Avatar
Oil pressure light stays on until the system registers enough pressure to make it go out. It usually takes a second or 2 longer than the other lights on cold start up. As long as it doesnt flicker on or stay on while you are driving then it should be ok. You should always check your oil level though as the light doesnt come on until the oil is really low.
You probably didnt pay as much attention to the oil light until after you changed the TCT.
http://www.youtube.com/watch?v=8XO14Ql5HmE
Video: Sorry about the second start up, I just wanted to see how quickly it went out. Keep in mind the car wasn't completely cold despite displaying only 1 bar. It had been driven about 5 hours ago. It definitely stays on longer in the morning on a true cold start-up.
Marioshi is offline
Old 10-02-2010, 06:15 AM
LOL..that's what my friend suggested. I just couldn't believe him until I hear from a stewie owner .
Thank you so much for the relief.
Old 10-02-2010, 03:27 PM
I got a fuel pressure warning from my SPA gauge but there was no impact on performance. So I checked the wiring and found a loose grounding screw. An easy fix. If an oil pressure warning happened I would shut the car down immediately.
desmo4 is offline
Old 10-02-2010, 06:32 PM
Definitely...an oil pressure light is something I take very seriously. However, in my case it just stays on for a very short time, and only in cold starts. I haven't detected anything unusual in the car as well. I never noticed the light before changing the TCT. Maybe after changing it, I started looking for any changes, and that when I noticed it.
Thanks for your input, Jonathan .
Old 10-18-2010, 05:38 AM
Croc's Avatar
few days ago i measured for how long oil press light remains on - on a cold start it's close to 1 sec, on a hot start it turns off almost immidiately.
Croc is offline
Old 10-18-2010, 07:12 AM
nateman101's Avatar
Originally Posted by the.aviator2 View Post
Hi guys,
Thanks in advance,
How much did that cost and how many miles?
nateman101 is offline
Old 10-18-2010, 09:05 AM
tct runs around $125
you can take it off, take it apart, sand the worm gear and reassemble for free.
turbosix is offline
Old 10-18-2010, 04:12 PM
worry about it if it stays on. do check your oil.
bbcricketta is offline
Old 10-18-2010, 06:37 PM
I can't really remember(been few months since then), but I'm pretty sure it's like what turbosix said. I changed it myself; it wasn't a hassle.
My stewie has 146k on it I just changed the oil this afternoon.
@bbcricketta
thanks bud, I do check the oil every two or three days.
Old 10-18-2010, 09:43 PM
what oil are you using?
philiam is offline
Old 10-19-2010, 03:17 PM
Actually I tried different brands just to see if one will burn more than the others, and yup, I noticed a difference.
The first one I tried was full synthetic Mobile1 10-30W. in my 3000miles I added 1.5quarts.
In the second time, I decided to go with Castrol Edge 10-30W, and with the same 3000miles I added about 2 quarts.
The last one I tried is Castrol Syntec.This one was horrible. I remember buying three if not four quarts (I believe three), and I reached my changing time with a very LOW oil level.
Considering my experience above, This time I went back to mobile1 which I've always trusted.
Old 05-12-2012, 10:24 AM
Decepticon S2K's Avatar
what about an oil pressure light that blinks once only on cold start up and never blinks while driving...anybody got any ideas on that one...i have monitored it during driving and not a blink...but one blink randomly (not all the time) on cold start up
Decepticon S2K is offline
Old 05-14-2012, 07:49 AM
this is normal. there's no oil pressure when you go to start the car.
turbosix is offline
Old 05-16-2012, 12:39 AM
turbosix...lets hope so buddy...got my oil pressure test in 6 hours at the dealership...crossing fingers and praying for good numbers
Old 05-16-2012, 05:46 AM
House of CR.
Vanishing Point's Avatar
Compression test, correct. Not oil pressure test.
Vanishing Point is offline
Blackhatch89
12-22-2014 06:08 AM
hussam
Parts For Sale
05-27-2013 08:03 PM
fr3sh2k
08-23-2012 06:54 PM
Decepticon S2K
22
06-18-2012 06:04 AM
dingleberries
09-18-2009 06:45 PM
Quick Reply: Oil pressure light on
