transmission leaking oil
Old 09-13-2010, 04:23 AM
wheelspk's Avatar
hello,
had a problem with my transmission before as discussed here before,
https://www.s2000.com/forums/engine-...too-loose.html
got that fixed!
i was really happy with my car but last night with the top down i noticed a smell of burning oil, taught it must have been tranny oil drops when i had it remove before ,on the exhaust or some thing, but there were new grinding noise also noticeable at about 3 to 5k RPM.
in the morning i noticed there was a lot of oil under the car( around 1/2 a liter or so) ,and where the shaft fits the gearbox, the exhaust and the rear Differential.
what could cause the leak? is it a seal or some thing? or the gear box guy didnt seal the gear properly? if yes what seal do i need to get rid of the leakage?
i didnt drive the car much after i heard the grinding noises, will those noises go away when i put back the new transmission oil?
this s2000 transmission is getting to be a BIG PAIN IN THE A$$$$$$$.....
please help me out as u all have in the past...
thanks
osman
wheelspk is offline
Old 09-13-2010, 05:47 AM
wheelspk's Avatar
anybody?
wheelspk is offline
Old 09-13-2010, 05:07 PM
TTMartin's Avatar
Originally Posted by wheelspk View Post
hello,
got that fixed!
thanks
osman
I'm guessing
#16 O-RING
#15 OIL SEAL
http://www.hondaautomotiveparts.com/...ECONDARY+SHAFT
TTMartin is offline
Old 09-14-2010, 04:43 AM
TTMartin's Avatar
You might have your gear guy check the install and bearings on that aftermarket secondary shaft, while you are doing this.
TTMartin is offline
Old 09-14-2010, 06:19 AM
wheelspk's Avatar
found the problem!
it was a loose nut on the case from which the oil was coming out of....
it was a case of not rechecking
wheelspk is offline
Old 09-14-2010, 06:26 AM
At least it was an easy fix!!!
Old 09-14-2010, 08:35 AM
Nice work!
deeno35 is offline
Blazinbower
04-22-2009 10:13 AM
JDMHonda
15
04-13-2009 06:36 AM
crazwhiteboy
11-08-2007 06:20 PM
freestyler
10-24-2005 03:47 AM
Anonymous
06-19-2003 03:04 PM
Quick Reply: transmission leaking oil
