Is it really mandatory to open bleeder screw before pushing back pistons? - S2000 Forums
Go Back  S2000 Forums > Technical > All Other Honda S2000 Related Discussions
Is it really mandatory to open bleeder screw before pushing back pistons? >
Old 03-14-2015, 02:15 PM
Hello, fellow members.
I'm going to change all brake pads in this week and have few questions. It's my first time changing pads after 50,000 miles in s2k and have only basic knowledge.
after many research, i saw other members highly recommending opening bleeder screw prior to pushing back pistons and bleed brake system as well. However, i had my mechanic flush new brake fluid less than 10,000 miles ago. And i'm not sure if bleeding is necessary this time
Do you guys push back pistons while master cylinder cap is open? or bleeder screw is open?
If i were going to push back pistons while bleeder screw is open, is there any chance air might get in the system?
Please share your opinions!
Thank you
-Joo
joo lee is offline
Old 03-15-2015, 12:27 PM
Never Slow down
Wayne's Avatar
You do not need to open the bleeders when pushing the pistons back into the calipher. You can take the cap off the reservoir and push them back in slowly. When you are finished pump the brake pedal and it should come up and feel hard. If it feels spongy you should bleed the brakes.
Wayne is offline
Old 03-15-2015, 04:25 PM
just havin' fun
will williams's Avatar
The only reason why you would do that is if the reservoir is already full. When you push back the piston all the fluid will be pushed back and the reservoir will overflow.
will williams is offline
Old 03-15-2015, 06:02 PM
2009 Rio Yellow/A7E/A330
cosmomiller's Avatar
If overflowing were an issue you could also suck some out of the reservoir.
cosmomiller is offline
S2Krazy21
02-26-2012 01:59 PM
smokeeater15
07-06-2011 05:39 PM
fastludeh22
Want to Buy/Trade For
02-10-2010 07:47 PM
ShahzebN
08-03-2009 07:47 AM
s2kam
10-16-2005 08:54 PM
Quick Reply: Is it really mandatory to open bleeder screw before pushing back pistons?
