Torin 3 ton aluminum jack stands
Old 08-01-2012, 10:20 AM
2009 Rio Yellow/A7E/A330
cosmomiller's Avatar
Was thinking of picking up a pair. Any comments from anyone?
cosmomiller is offline
Old 08-01-2012, 11:01 AM
General Nuisance
Doug3's Avatar
THe reviews are good. I like the flat base plate.
http://www.amazon.com/Torin-T43004-A...owViewpoints=1
Doug3 is offline
Old 08-01-2012, 11:05 AM
probably ok. i got 3000 pound jackstands from harbor freight. they do look flimsy, but as long as they don't collapse. as i recall, it is the pair of jackstands that is rated at 3000 pounds and it is not recommended that you ever use just one jackstand by itself. i prefer 4 jackstands. lift the front and then the rear, with the car in gear and the e-brake applied. i would not ever raise the rear alone unless i was absolutely sure the front was secure. i prefer to raise the front and then the rear if i need to raise the rear. i always like to add another layer of protection by putting something under a tire or the frame to support the car in case of a failure. i will put my fat **** under a car on stands but i am never completely comfortable with it. personal opinion is that you should get 4 rather than 2.
We are the largest manufacturer of hydraulic jacks and tool boxes in the world. The Torin factory in Changshu, China encompasses 106,400 square meters with a 138,000 square meter addition planned for 2006.Torin recently moved into a brand new 100,000 square foot facility in Ontario, California.
Last edited by bbcricketta; 08-01-2012 at 11:11 AM. Reason: practicin' my mandarin...
bbcricketta is offline
Old 08-01-2012, 12:18 PM
I have an older pair of 3.5 ton steel jack stands that have been in continuous use for 15 years (keep a trailer off the ground) that is going to round out the jack stand team for me. I intend to use the mix of 4 jack stands and use the jack on the front center (engine) jack point to add some redundacy as I attack the trainie and diff. Will probably add some wood backup too, maybe a spare tire, as I just heard of a colleague of mine who was crushed when he torqued a bit to hard on his shocks and the car (not an S) fell off his 4 jackstands. I like the Torin engineering better but the base is not as large as other footprints. Is it unstable? Does it really matter if you give the beast a good shake before getting under?
Old 08-01-2012, 12:41 PM
toyrunner's Avatar
I have 2 Ton Big Red jack stands, 4 of them. Good for a fraction of the ones listed .
toyrunner is offline
Jim21680
10-17-2011 07:41 PM
s2kdan87
South West
01-31-2009 08:39 AM
Wolfenstein
14
11-26-2008 09:58 PM
SXY_S2K
27
07-30-2008 07:35 AM
justin
06-10-2005 06:34 AM
Quick Reply: Torin 3 ton aluminum jack stands
