Alarm issues
Old 07-17-2011, 07:28 AM
Alarm issues
Hi,
Any help/ideas with the following would be appreciated.
Have had my S2000 for over a year without any issues. I haven't driven it for three weeks but have otherwise used it fairly consistently.
Went to open the car this morning and the alarm went off when I pressed the "open" button. The door would then not open, despite me pressing the "open" button a couple of times. The boot, however, would.
I eventually used the key to open the door, which set a whole new and louder alarm off. I thought this would all stop as and when I tried to turn the car over. It did not and the car will not start.
The alarm stops after a while but, as soon as I put the key back in the ignition, it starts again.
I am thinking a) the immobiliser needs resetting or b) it/the electronic key is screwed. Any ideas how to reset it? Or anything else I could do to try and overcome this?
Otherwise, think it will be on the back of a truck to a Honda dealer pretty soon for an expensive trip!
LPCMan is offline
Old 07-17-2011, 08:01 AM
EYECELLEM
The car did not come from Honda with an alarm system. So, you either have an aftermarket or the Honda accessory alarm system. Try replacing the battery in your key fob. A weak battery may not be sending a signal to the system to disarm it and unlock your door.
Glenn1 is offline
Old 07-18-2011, 09:52 AM
Hmm, ok. Thought they did. Mine is a UK car if that makes any difference.
Either way that is useful, thank you. I will try that.
LPCMan is offline
Old 07-18-2011, 10:09 AM
reminds me of jeremy clarkson's immobiliser issues on his ford gt.
the car didn't come with an alarm but his insurance company mandated that one be installed otherwise they wouldn't insure it.
is that standard practice over there?
turbosix is offline
i'd also check your battery. an almost dead battery usually makes alarm systems freak out. can you pull the battery and take it to an auto shop to get tested?
turbosix is offline
Old 01-31-2012, 08:04 AM
My 04 UK registered car has developed a new alarm feature! When I put the car in the garage, I lock it using the remote or rely on auto re-lock. Then when I close the garage door (a metal "up and over" type door), the car alarm sometimes goes off. Anybody any ideas, I didn't think the alarm had any sort of proximity sensing capability or is it a change in air pressure setting some form of internal motion sensor (in which case why doesn't it go off when my cat sleeps on the hood when the car is parked outside in the sun)?
RichardH is offline
Old 01-31-2012, 09:10 AM
Bug Zapper
Marioshi's Avatar
As mentioned above, S2000s didnt come with an alarm so yours is aftermarket. There is a good chance it does have some sort of proximity sensor. My aftermarket alarm does.
Mine goes off all sorts of random times and sometimes not at all when it should. Just the nature of alarms I guess.
Marioshi is offline
Old 01-31-2012, 01:39 PM
EYECELLEM
^^proximity or noise setting it off? When it's quiet (at nighttime), the sound of the sliding door may be setting it off
Glenn1 is offline
Old 02-01-2012, 05:39 AM
Thanks for the replies. No it's not an aftermarket alarm, the car is stock UK spec. As for noise, now I always close the garage door slowly (in case it's a change of pressure thing) so door closure is quiet. Carry on being mystified I guess.
RichardH is offline
Old 02-28-2012, 11:38 AM
I have a 2000 and a 2002 and they both have honda oem alarms.
jsenclosures is offline
Old 02-28-2012, 09:10 PM
EYECELLEM
^^Yes, if your car is US spec, it was installed at the dealership as an OEM accessory. It does not come from Honda with an alarm already in place. The remote entry is simply that, remote entry with panic button.
Glenn1 is offline
Old 03-03-2012, 09:59 AM
Custom User Title
Alittle off topic but does do the alarms from honda actually work? Ever since I had the car Ive never heard the alarm go off for any reason.. The clicker and everything works, just you can probably get inside the car and roll it down the street and the alarm wont say a word.. I think it wants to be stolen..
_brandon is offline
IndianaBeck
12
01-27-2010 08:10 AM
wowowox
02-16-2006 06:00 PM
sunnyyan
09-21-2005 08:33 PM
ChippedS2k
07-09-2004 03:52 PM
Anonymous
10-10-2003 07:18 PM
Quick Reply: Alarm issues
