Old 12-19-2007, 06:04 PM   #1 (permalink)
SilverS2K422
B.A.M.F.
SilverS2K422's Avatar
tires?
Im looking to get some better tires for my 02 s2k stock wheels. I want wider tires. Does anyone know what the widest tires i can go with the stock wheels?? I have 205 in the front and 225 in the rear could i put the rear tires on the front and get wider on the back b/c my rear tires are good and front are crap.
Any info would be appriciated. Thanks
Old 12-20-2007, 01:02 PM   #2 (permalink)
Bubblerboy64
I think you are lookin to make a lot of trouble for yourself. I would replace the tires with the tires that came on the car new or at the very least the same size tires from a compariable brand. In my opinion you can't add much to a S2000 to improve it over stock. From all that I have read on this forum you gain next to nothing perhaps 5 to 10 percent and spend big bucks to do even that. And I would suspect even the guys who have gone to larger tires will tell you that wheels will also be needed. Why would you want to mess with what works so nicely. JEH
Old 12-20-2007, 02:01 PM   #3 (permalink)
DJJSR
DJJSR's Avatar
You guys may already know this but the cars have now been equipped with 215/45 x 17" up front and 245/40 x 17" on the rear, stock. That's pretty wide for the size of the car.
Don
Old 12-20-2007, 10:33 PM   #4 (permalink)
SilverS2K422
B.A.M.F.
i have 205 in front and 225 in back thats tiny! but how wide could i go im not saying i want 305 or some crazy size i just wanna know.
thanks
Old 12-20-2007, 11:51 PM   #5 (permalink)
State'cher purpose lad!
R' we talkin' for handlin' 'r are we talkin' an offerin' on the altar'a the groovy gods'a style n' looks?
Totally diff'rent animals Sil with totally diff'rent solutions.
Tiny? Compared to what?
Old 12-23-2007, 12:00 AM   #6 (permalink)
Vezna31
Vezna31's Avatar
If you're not going with stock S02's then you need to go 225 in front and 245 in the rear on the 16" wheels.
http://www.vezna.com
Old 12-23-2007, 07:20 AM   #7 (permalink)
The best improvement you can make in tires is to Buy Potensa RE-01R tires in the stock sizes. If you are in an area which is warm all year they will out perform SO2's in dry or wet. But the S will always wear the rear tires first at about a 2:1 ratio. That is the nature of the beast. Change the stagger and watch the the crash from the windshield or the mirror depending on your skill.
Old 12-31-2007, 03:53 PM   #8 (permalink)
Fighting For Air
Yah mon, it's irie !!!
Fighting For Air's Avatar
Anybody running Toyo R888, RA1s, or Falken Azenis?
Have heard the new Azenis don't get as greasy on longer autocross runs as the old ones. Curious if that is true.
I've run RA1s before and like the fact that they are almost as grippy as Yokohoma A048s but don't heat cycle out as quickly like the Yokos - stay pretty sticky through the life of the tire.
Never run the R888 and would be curious to hear a report.
I just picked up a CR a few weeks ago and would like to mod wheels and tires right away before autocross season so I have some time to dial things in. Am thinking of dropping down to 16s and perhaps keeping stock tire widths of 215 up front and 255 in the rear.
- Rob O'
Fighting For Air is offline   Reply With Quote
Old 12-31-2007, 04:23 PM   #9 (permalink)
Vezna31
Vezna31's Avatar
I run RA-1's on the racetrack and on mountain drives. I love the feel and predictability.
Old 12-31-2007, 07:17 PM   #10 (permalink)
I have run 225/50 on front and 245/45 on the rear, but that was with Kuhmo Victoracers. I actually ran 265 on the rear for 1 season. It can be done.
Old 02-20-2008, 05:29 PM   #11 (permalink)
acctlab5
I run the old Azenis on the F(205/55) new on the R(225/50)on the OEM wheels.
For a daily driver setup,I liked the old tire better.I have 30K on the front but it'sime to replace.
The new Azenis doesn't come in 205/55/16.
\db2
Carolina
acctlab5 is offline   Reply With Quote
Old 02-20-2008, 05:34 PM   #12 (permalink)
Vezna31
Vezna31's Avatar
\db2
Carolina
You should run 225 in front and 245 in rear if not using OEM S02's. S02's were made larger than other brands.
Old 02-20-2008, 08:32 PM   #13 (permalink)
fhinner
fhinner's Avatar
Send a message via Yahoo to fhinner
Instead of Toyo or Falken, I would go for BF Goodrich. However, I wouldn't upgrade the wheel size for handling reasons. Did that and it took some adjustment on the setup, just to form 16" to 17". So if you really wanna go that wide, don't expect magic on handling...well and then don't worry about what tire you buy...
F
fhinner is offline   Reply With Quote
Content Relevant URLs by vBSEO 3.0.0
