Won't start - S2000 Forums
Old 12-23-2016, 12:58 PM   #1
Won't start
I change my accessory power relay, on my 2008 unplugged all four relays in the block plug them back in in the same order now my car won't start .
HAM08AP2 is offline   Reply With Quote
Old 12-24-2016, 05:27 AM   #2
First, double-check to see that they are in the correct position. If so, pull them out one at a time and clean all of the contacts so they're nice and shiny. Spray a bit of WD-40 in the socket and replace. If not, clean as above and install correctly.
Car won't start cranks over has spark fuel and timing is correct need help Brett B Engine Tech / Drivetrain 11 07-25-2016 01:30 PM
Won't Start after 4 month Winter sitting! klinkston New s2000.com Member Area / Introductions 35 05-11-2012 01:04 PM
help! car won't start es too YAY Engine Tech / Drivetrain 9 04-19-2011 09:15 PM
Car won't start Gunzi All Other Honda S2000 Related Discussions 6 03-22-2011 02:21 PM
Car won't start miyu Interior / Audio / Electronics 5 01-17-2011 09:46 AM
Search this Thread:
Advanced Search
