Start button doesn't work - S2000 Forums
Old 11-08-2016, 05:50 PM   #1
Hello everyone.
I need some help on the start button on a 2002 it doesn't do anything at all when I push it the only way to start the car is by push starting the car. Can someone please help me?
Hangman85 is offline   Reply With Quote
Old 11-09-2016, 12:38 AM   #2
Are you pushing in the clutch when you try to start the car?
Old 11-09-2016, 07:36 AM   #3
Yes I did, but nothing happens. Any suggestions?
Old 11-09-2016, 11:45 AM   #4
Yes I'm pushing the clutch. Do you have any suggestions?
Old 11-09-2016, 02:34 PM   #5
Got S2000?
You can begin by checking the switch itself. Find out how to take it out and check the contacts, etc. There's a few threads on this, but it doesn't look very easy.
But before you do that, at least check the fuses (I don't think the car would start at all if one were blown, but not sure). It's certainly easy enough to try.
Good luck! Let us know how you make out.
Old 11-10-2016, 01:38 AM   #6
There is a switch that activates when you push the clutch in. It has a rubber pad that is supposed to actuate it when the clutch is pushed in. That rubber pad can disintegrate and then the switch doesn't actuate. Look under the dash around the clutch pedal.
Old 11-10-2016, 12:50 PM   #7
Would you have a photo of that, so I can know what you are talking about?
Old 11-10-2016, 07:47 PM   #8
Got S2000?
Open the driver door, and get down on your knees. You already have a flashlight in your hand, right?
Depress the clutch pedal with your hand, and observe what's happening with the linkage and clutch lever, etc. You should see that rubber switch somewhere; it should be an easy sight.
Old 11-14-2016, 05:08 AM   #9
The rubber pad/disc is attached to the arm of the clutch pedal and depresses a micro switch with is a clutch interlock. I just replaced the pad on my Nissan Frontier this weekend, proving once again that Nissan parts is a rip off, 13 bucks for a plastic/ rubber disc 2/3 the size of a penny.
cdk456 is offline   Reply With Quote
Old 11-14-2016, 09:31 AM   #10
Look at part 11 and 13 HERE. That's the actuator switch and the pad.
Old 11-14-2016, 10:10 PM   #11
2009 Rio Yellow/A7E/A330
cosmomiller's Avatar
How often do these bad boys go bad? Is it advisable to get one (before you cannot) to have ready when the old one fails?
cosmomiller is offline   Reply With Quote
Old 11-15-2016, 12:42 AM   #12
It's a now and then thing. I doubt anyone has really figured out how long they last. They're protected to some extent by where they are. Personally, I'd say just to take a look at them every now and then.
Old 11-16-2016, 08:15 AM   #13
Thanks! I will look for that.
Old 12-21-2016, 12:00 PM   #14
Thanks for the help. That has solved everything and now the S is alive!
Old 12-22-2016, 05:12 AM   #15
Glad you got it fixed!
Old 12-22-2016, 04:51 PM   #16
Not a problem, glad to help.
Trunk Light Doesn't Work! ap1808 Interior / Audio / Electronics 5 05-21-2012 01:18 PM
Dashboard mute button doesn't work ichi Interior / Audio / Electronics 4 05-11-2010 02:51 AM
Power Outlet Doesn't Work AZS2K Interior / Audio / Electronics 7 11-11-2009 01:35 PM
Replacing the "Engine Start" button dhend25 Interior / Audio / Electronics 10 03-08-2009 05:04 PM
Start Button Dr. Jimbo Interior / Audio / Electronics 10 02-23-2008 09:55 AM
Search this Thread:
Advanced Search
