OBD Port Location - S2000 Forums
Old 07-30-2009, 09:25 PM   #1
redS2k06's Avatar
OBD Port Location
I have a check engine light on, i am looking to pull the engine code using the obd 2 code reader but i am unable to find the obd 2 port. I have a 2006 honda s2000, can someone please post a picture of where the port is
redS2k06 is offline   Reply With Quote
Old 07-31-2009, 04:27 AM   #2
mlc
mlc's Avatar
I have an AP1. Mine is on the passenger side. If you look at the tranny hump there is a small triangular pad just above the net. Almost like a knee pad for the passenger. Go to the point of the triangle were it meets the dash. Look up under the dash there it is a small grey connector.
I hope that makes sence.
Kevin
Old 07-31-2009, 05:18 AM   #3
Colo Spgs
OBD II Location
I found this on-line a couple weeks back. Type in the model/make/year. Results will give you a drawing and photo location for your port. Like mlc said, my '02 is on the tranny hump
I just looked and it lists up to 2005. Maybe the '06 is in the same location?
Hope this helps
Shook
http://www.obdclearinghouse.com/
bryshook is offline   Reply With Quote
Old 07-31-2009, 05:40 AM   #4
The Cheeziest!
MutantCheese's Avatar
On my 2008 the OBD port is on the drivers side on the hump just past where the center console plastic stops. It's nearly impossible to see.
Old 07-31-2009, 05:53 AM   #5
my 2002 is in the same location.
Old 07-31-2009, 06:00 AM   #6
mlc
mlc's Avatar
Kevin
Mine is a MY00
Old 07-31-2009, 07:05 AM   #7
It's on the driver side to the right of the steering column, slightly behind where the the underside of the dash ends. If you reach up like you want to reach over the radio, you'll find the OBD...
Old 07-31-2009, 09:22 AM   #8
redS2k06's Avatar
thanks everyone I finally found it. I could see a diagram in a downloaded service manual.
Old 07-31-2009, 09:54 AM   #9
mlc
mlc's Avatar
When you pull the code if you need some help let us know what it is. Most here have had just about everyone you can think of.
Kevin
Old 07-31-2009, 03:13 PM   #10
On S2KCA search for "codes" and you will find a post with all of them.
Old 05-15-2011, 06:19 PM   #11
honda s2000 ap2 2006+ iso9141 coolant temperature data help needed!
Any one in this forum could help me with data of coolant id in this s2000, I am doing a reverse engineering of this cluster and need some data.
All the cluster I could make fully functional, except the coolant temperature display.
Can some one tell me any information in regards what message is for coolant temperature 19 segments on s2000 ap2 year 2006 display?
Cheers!
Bravo_Nild is offline   Reply With Quote
Old 05-15-2011, 06:29 PM   #12
Smile DO YOU CONFIRM HONDA S2000 AP2 YEAR 2006+ WORKS ISO9141-2?
Can any honest soul tell me exactly what protocol all this obd2 port works?
HONDA S2000 AP2 YEAR 2006+ IS IT?
ISO 9141-2 (Asynchronous serial communication at 10.4 Kbaud)
Pin 7: K-line bidirectional for communication
Pin 15: L-line (optional) unidirectional for waking up the ECU
Idle signal levels are high
Signals are active pull-down to 0V (0.00 to 2.40)
High signal voltage level: +12V (min/max 9.60 to 13.5)
Up to 12 message bytes, excluding frame delimiters
Bit Timing;
UART signaling at 10.4K baud, 8 data bits, no parity, 1 stop
IS THIS INFORMATION CORRECT? PLEASE ANY ONE WITH ANY KIND OF SCANNER OR TOOL, PLEASE HELP ME ........
IT IS ABOUT MANY MONTHS TRYING TO FIND THIS!
Old 05-16-2011, 07:23 AM   #13
Kalm_Traveler's Avatar
I'll check with my laptop when I get home - bought one of those USB-OBD2 things off Amazon and it works really well
Old 09-03-2011, 09:04 AM   #14
OBD2 connector LOCATION
I don't know about your S2000, but on my Model Year 2001, the OBD2 connector is located vertically on the left side of the PASSENGER side of the car right above the little cargo net. It is NOT on the DRIVER'S side AT ALL!
territet is offline   Reply With Quote
Old 09-06-2011, 01:40 PM   #15
sp00led's Avatar
00-01 are on the passenger for sure. I'm pretty sure all the 02' and up are on the drivers side.
sp00led is offline   Reply With Quote
OBD 2? Grounded Engine Tech / Drivetrain 31 09-03-2011 09:02 AM
Custom USB Port Matt_05AP2 Interior / Audio / Electronics 11 11-15-2010 02:09 PM
OBD-II scan tool: questions & advice sought. RMurphy Engine Tech / Drivetrain 27 08-02-2010 02:13 PM
Car meets around Tampa/New Port Richey C Dub South 2 01-29-2009 08:16 PM
Where is the ODBII Port? Has anyone tried the Palm-Dyno? smokin_s4 All Other Honda S2000 Related Discussions 0 07-18-2003 07:16 PM
2001, 2006, 2009, board, civic, connector, diagnostic, honda, ii, location, obd, obd2, odb, port, s2000, service
Search this Thread:
Advanced Search
