what type of brake fluid to use for clutch?
what is the best type of brake fliud for the s2000. im gona change the clutch fliud cause its getting too dark.
Use the recommended. Check the owner's manual.
what is it? I didnt get a manual with the car.
Use Honda Heavy Duty Brake Fluid DOT 3 for a 2006 car. It says if you cannot get the Honda fluid then use a DOT 3 or DOT 4 fluid, but flush the system and replace it with the Honda DOT 3 fluid as soon as possible.
Thanks Man!! hoping this will help sol
ve my 2nd grind issue! |
are you sure you didn't get a manual? did you check the secret compartment?
i need a better signature. |
FWIW you can download the manual. Not as good as having it in the car, but at least you can read it. Mine didn't come with a manual either.
I use Motul 600 for brake and clutch fluid. Never have a problem. It gets changed about 3 times a year from many miles due to being a daily driver and track days.
Same here Motul 600 in everything and I put on a set of Speed Bleeders so brake or clutch fluid change is as easy for one person to do without any extra appliances.
