Car won't start cranks over has spark fuel and timing is correct need help - S2000 Forums
Old 07-21-2016, 06:42 AM   #1
I have a 03 ap1 with 131k miles no leaks ran great until I got on the highway running in 5th about 4500 rpm rpm then down shifted to 3rd on accident and it went up to 8,000 rpm red lines at 9 after that happened the car sputtered out no wont start any help is appreciated checked all fuses seemed good one fuse on driver side box under the hood with no diagram a 50amp was blown so replaced it still doesn't start battery is good also
Brett B is offline   Reply With Quote
Old 07-21-2016, 09:06 PM   #2
2009 Rio Yellow/A7E/A330
cosmomiller's Avatar
Okay, you have an 03 AP1 with 131K miles on the clock. Runs well, no issues. You were driving in 5th at 4500 rpm and accidentally downshifted causing a mechanical over rev. Not sure how far: you said 8K rpm but mention 9K rpm. After the over rev the engine dies and will not start. You state you checked fuses and found one 50 amp fuse was blown but replacement did not fix the start problem. You don't believe the battery is a problem.
Good so far? When you state the car will not start do you mean to say the engine will not turn over at all or do you mean it will turn over but only cranks with out firing?
Most of the time a mechanical over rev that you described will cause the valve retainer to crack, the valves could drop to the combustion chamber and hit the piston. Then valves may be bent or broken, valve seats damaged, valve guide twisted and you can see these metals when you start taking it apart. It may be just a head issue but if stuff dropped into the cylinders you are talking about an engine replacement.
I think best case scenario is to have a new cylinder head, worst is to replace the whole engine...think positive, it's time to have a newer engine isn't it?
cosmomiller is offline   Reply With Quote
Old 07-22-2016, 05:21 AM   #3
I thought of this right away. For OP's case I hope not but it doesn't sound good.....
Old 07-22-2016, 06:09 AM   #4
i agree that it sounds like a mechanical over-rev, but...
how does a down shift from 5th gear at 4500 rpm to 3rd gear, unintentional or intentional, cause an over-rev? the down shift to 3rd should should only take the tach to 6500-7000 rpm with plenty of safe space left on the rev counter. maybe it was a downshift to 1st, but that is extremely hard to do, even for a tyro. a downshift to 2nd would be pushing it but i believe that it might be possible without a mechanical over-rev.
i think something else happened here.
131,000 on the ODO is just getting broken in good.
OP says the tach went to 8,000 and that the engine red lines at 9,000.
downshifting from 5th to 3rd is a no-no for the transmission but that should not affect the engine.
at 8,000 rpm the AP1 is cookin' but far from exceeding its capabilities.
more factual information is needed to help OP with his problem.
bb
Old 07-22-2016, 07:31 AM   #5
bb
Just dealing with the cards that you were dealt with!:hard:
Might be a troll.
Old 07-22-2016, 10:07 AM   #6
Car won't start
The engine cranks over but will not start has fire on all plugs, checked compression yesterday all read different 1st one is 30 2nd one is 20ish 3rd 120 4th one is 50 could it have dropped a vale or lost some compression and need head work done now but it never went in the red after the accidental down shift ? Timing is still spot on timing chain is not to loose haven't checked the bottom end yet
Old 07-22-2016, 10:39 AM   #7
EYECELLEM
Glenn1's Avatar
The 03 AP1 has a 9000 rpm redline, unlike the 04 to 09 AP2 with the 8100 rpm redline. But, based on your explanation it's possible you exceeded the maximum engine speed and never saw it on the tach. So, bent valve, etc...
Old 07-22-2016, 11:34 AM   #8
Car won't start
I was thinking maybe that but I also blew air in each cylinder and some air came through the number 1 cylinder and some air came out of the number 2 cylinder which shouldn't happen, maybe time for new Pistons and rings and vales plus springs I don't mind rebuilding it but I'm trying to stay around 5,000 in parts or if I can replace the Pistons and rings and vales cam seems good and timing chain is not worn out or the teeth
Old 07-22-2016, 01:31 PM   #9
Many have gone down this road and found it is cheaper and a time saver to purchase a good used engine than rebuild the destroyed engine. They are out there.
Old 07-23-2016, 04:16 PM   #10
Car won't start
Okay I dug deeper and found that the retaining valves on the inlet side are all cracked which I'm told may not let them open and close properly I am going to change the valves to ap2 vales hopefully this fixes my issue
Old 07-25-2016, 05:09 AM   #11
Good luck! Hope it works for you!
Old 07-25-2016, 12:30 PM   #12
Originally Posted by Brett B View Post
Okay I dug deeper and found that the retaining valves on the inlet side are all cracked which I'm told may not let them open and close properly. I am going to change the valves to ap2 valves hopefully this fixes my issue
valve retainers.
i was traveling in 5th gear yesterday and intentionally shifted to 3rd, tach bumped up to about 6500 and i cruised off into the sunset.
Swapped from a ap1 to ap2 motor has error code crankshaft sensor won't turn over Freddyrosario1 Engine Tech / Drivetrain 0 12-14-2015 07:49 PM
02 S2k cranks and will not start NavyAT2000 Engine Tech / Drivetrain 11 01-10-2015 08:20 PM
help! car won't start es too YAY Engine Tech / Drivetrain 9 04-19-2011 08:15 PM
2001 s2000 cranks, bucks and no start? fast_s14 Engine Tech / Drivetrain 1 05-20-2009 10:48 AM
engine fuel cut off and timing belt surfer Engine Tech / Drivetrain 7 04-05-2008 09:41 AM
Search this Thread:
Advanced Search
