ABS Light always on - S2000 Forums
Old 06-29-2010, 07:02 AM   #1
ABS Light always on
Hi all! Just joined here! I bought a 2001 S2000 a couple of weeks ago.
Verry happy with my new car.
However...
when i bought the car, there was a piece of black tape on the dash, which i only noticed a few days after buying the car. Turns out that the tape was covering up the ABS light. which is always on when the car is running.
i did a bit of testing on my brakes, and they will lock up if you brake hard at about 40mph.
i understand i should take it to honda and get it checked out. what do you guys think the problem would be? gunna cost me loads to fix?
samsamm777 is offline   Reply With Quote
Old 06-29-2010, 10:16 AM   #2
Kalm_Traveler's Avatar
I sorta wish ABS wasn't legally required...
could be all sorts of things though. Is your Engine light on as well or just the ABS one?
are you low/leaking brake fluid? is your ABS controller plugged in?
Old 06-29-2010, 10:35 AM   #3
i think you have a case in court against the seller if they were intentionally hiding a potential problem.
i'd speak with an attorney...
Old 06-29-2010, 10:37 AM   #4
Old Guy's Avatar
I would definately take it in and get it checked out. A little scary to think someone specifically covered it with black tape. Sounds like they were hiding something.
Old Guy is offline   Reply With Quote
Old 06-29-2010, 10:38 AM   #5
Old Guy's Avatar
If it's not too late, take pictures.
Old 06-29-2010, 12:56 PM   #6
Bug Zapper
Marioshi's Avatar
Black tape is how you deal with a light when it wont go off! Its straight from the "guide to owning 15+ year old cars" but I think I would get the ABS fixed on a 2001 that I was planning on driving fast.
Marioshi is offline   Reply With Quote
Old 06-29-2010, 01:06 PM   #7
Bug Zapper
Marioshi's Avatar
Its not according to IIHS and NHTSA. I have a 2007 Nissan Versa that does not have ABS. This is probably because they have not found clear evidence that they reduce accidents. 2007 and on requires TPMS and 100% of passanger vehicles will be required to have TSC by MY 2012.
I would halfway assume that if TSC is required that ABS probably be apart of all 2012s as well.
Old 07-16-2010, 08:58 PM   #8
thanks for the advice. ill take it in and get it checked out!
the brakes seem to work fine, and dont leak anything on my drive. we'll see what honda says.
Old 07-16-2010, 09:49 PM   #9
Vezna31's Avatar
Low brake fluid will not make the ABS light go on. It will make the emergency brake light go on. Same with brake pads that are just about done. What I have found that will make the ABS light go on is tires that are completely worn out, especially if you are not running OEM tires.
The car is very sensitive to the slightest change and non-OEM tires might not be the same circumference. SO, when they are completely worn out, the tire RPM may be throwing the ABS sensor out of whack. As soon as I bought a new set of tires, my ABS light went off and never came back on.
Old 07-16-2010, 10:36 PM   #10
I agree with Vez.....this would be my experience with modern abs systems........
but who really cares if your abs isn't active........I'd almost prefer it wasn't.
Abs light help. s2k01 Engine Tech / Drivetrain 1 09-25-2012 06:58 AM
ABS Light on HELP!!! Max_Spd Engine Tech / Drivetrain 12 04-27-2011 06:16 PM
ABS light sequence not coming on VINNY Engine Tech / Drivetrain 0 12-01-2010 05:16 AM
ABS Light Vezna31 Wheels / Tires / Suspension 5 06-22-2010 06:33 AM
OEM NGK Plugs - Always price around!! dezignpro04 Engine Tech / Drivetrain 9 06-27-2008 06:34 PM
2007, abs, brake, constantly, fix, forum, honda, light, lower, make, nissan, pads, s2000, troubleshoot, versa
Search this Thread:
Advanced Search
